Nec Plasma having vertical line red colour thin line how i m resolved that issue can u help me.
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 17, 2013
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
  • 50 Answers
SOURCE: thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
Posted on Feb 27, 2008
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
SOURCE: Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Posted on Nov 21, 2008
DRACO A5OG
  • 22 Answers
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Posted on Dec 23, 2008
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Thin vertical red line on my LG 50PC56
First you must clean connector contacts between plasma module and driver boards, if not solve the problem and continuing increment of wide red line, may be you must change plasma module to solve this problem,
May 27, 2010 | Televison & Video
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
NEC px-42vp4g/s 42in.plasma monitor PDP:np42b3mf01...
I have the same problem with vertical coloured lines on my NEC PX-42VP4G/S. The photo only shows a black background just so it's easier to see the lines in the photo but normally the picture is OK except for the vertical lines which aren't always in the same place.
If anyone can advise on exactly what I need to replace then I would be very grateful.
Regards, Simon.
Apr 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
A Plasma TV
Sorry forgot to say ours is an NEC plasma PX42vp4g/s
Nov 18, 2007 | NEC PlasmaSync 61MP1 61 in. Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
