Question about Frigidaire FPHF2399M Stainless Steel Professional 22.6 Cubic Foot Fren
In-door icemaker stopped working ...no codes need service manual
    Scholar:
  • 111 Answers
Here is the information you were looking for, Hope this helps.
http://www.frigidaire.com/Owner-Center/Product-Support--Manuals/?productCode=FPHF2399MF
Posted on Oct 17, 2013
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Ice being trap behind the door; will not fall into glass
Refer this problem directly to Viking and also inquire about a service and parts manual.
Feb 09, 2014 | Viking Designer Series DFSB548D
Alliance Healthdyne oxygen concentrator alarm doesn't stop when turning the unit on.
There are parts inside that machine that have fixed hour ratings. When they are needing to be replaced, that machine has to be serviced. Since it is not an over the counter device, you need to contact a medical specialty vendor and have it worked on. There is no parts available.
Mar 28, 2013 | Air Purifiers
Everything works but the fan will not turn. I recently performed a thorough cleaning and installed a new ozone filter, but the fan will not turn. I tried turning the fan manually and the unit would run...
The fan needs oiling (except for the Fresh Air, which has sealed bearings and no removable front grid). I need to know which model you have to help you reach the fan shaft. However, if you're handy, you can figure it out. Remove the front grid (if there is one on your model) and pull off the fan blades. Use a light household oil (sewing machine, hair clipper, 3-in-1) to drip down the shaft as you turn it manually. This should take care of the problem.
If not, and if you need more extensive repairs or rebuilding, call Vollara (new name for EcoQuest) customer service at 1-800-989-2299 and use 16618 as your dealer referral number.
Jan 30, 2011 | Ecoquest Air Purifiers
I have a Living Water II installed under my sink. I would like to add a line to my refrigerator's ice-maker line. The plastic tubing supplied with Ecoquest and the line from the refrigerator ice-maker are...
Although your solution will work to supply water, the flow to the icemaker will probably not be high enough to turn the Living Water on to actually ozonate the water. Ecoquest does have a unit available, made just for icemakers.
Aug 11, 2009 | Ecoquest Air Purifiers
Ionic breeze stopped working
Check inside the unit to see if the two very fine wires which run from top to bottom are intact. My guess is one of them is broken, You'll need a very good flashlight to see them. If they are broken, tech service is the best way to get them fixed. Check your user manual for the service procedure -- if you don't have one let me know.
Mar 24, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Pure-Ion not working?
Didja wash the plates? It takes a little maintenance, and there are a lot of things that could make it stop working (Magnum, anti-aircraft fire, someone tripped over the cord, power quality in Karachi is lousy, there's pudding in the works...) but washing the plates with dishsoap and water, (then drying them before trying to start again) ought to fix most things that could be wrong.
Sometimes a fiber (a gift from a guest, maybe) is protruding into the works that needs to be removed, but those are the main reasons.
Jun 20, 2008 | Brookstone Pure-Ion UV Air Purifier
Just stopped working
Exactly the same thing happened to me. I get ** response from the unit. I may need to get it serviced from a local electrician as Brookstone is **t helping me.
Jul 29, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Frigidaire FPHF2399M Stainless Steel Professional 22.6 Cubic Foot Fren Logo
Top Frigidaire Air Purifiers Experts
Are you a Frigidaire Air Purifier Expert? Answer questions, earn points and help others
