Question about Craftsman Garden
13.5 hp Craftsman riding mower starts, and immediately starts pouring out tons of Black smoke. It will runs for 30 seconds to 3 or more minutes and eventually dies. Recently overfilled the with oil so I drained gas contaminated oil and refilled with 48 oz's of 30W as required. I pulled and cleaned new plug and turned the engine over for 15 sec and replaced. Now what?
    Sergeant:
  • 416 Answers
It sounds like the float is sticking. you may need to clean carb and change the float needle and seat
Posted on Oct 17, 2013
  • 5 Answers
SOURCE: Craftsman riding mower starts, then runs for 30
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Posted on Mar 22, 2009
SOURCE: Craftsman 56''mower draining new battery rapidly-not recharging...
JUNK IT ITS A PIECE OF ****
Posted on Jun 08, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 24 Answers
SOURCE: Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Posted on Aug 23, 2009
  • 133 Answers
SOURCE: I have an LT2000 Craftsman Riding Mower that
check the oil level might have low oil sensor on it. Also make sure the engine is clean (no built up oil and dirt on the motor itself or the fins on the motor)
Posted on May 24, 2010
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Governor hunts
Pour vinigar and hot pepper sparkles into the gas tank and mix it with the gas. Then start it- the differance in the way it runs will be very noticable!
May 22, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a 21.5 HP 42in. deck mower that I just bought (used), having a little trouble with. Mower starts fine, and runs great... until it heats up, then it starts spitting and sputtering, blows out black...
The black smoke is too much fuel, it is flooding out. Carb issue, I would pull the float bowl and clean carb, the needle in carb is stuck open pumping too much gas in.
Mar 19, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Not getting gas to combustion chamber, leaking gas from exhaust
Definitely the carburetor. Take it off and look for something clogged. Look carefully at the gaskets. Look for water and dirt in the float bowl.
Nov 23, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
57 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
