Question about Fujitsu Siemens LifeBook E8010 Notebook
My system not working.. when power on the machine will start( i think so), and the lcd on the key board displays battery status and some things.. feel a vibration like running machine.. but the problem is display not working..
    New Friend:
The problem gear
Posted on Oct 17, 2013
My laptop dell 3541 amd makes a loud beeps on starting up till the desktop appears .. any idea to solve this issue please ?
Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jun 21, 2015 | Dell Inspiron Computers & Internet
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Stanley 300 amp jump-start system status lights don't work. only low stays on
Sep 26, 2012 | Stanley 300 Amp w/12V USB Jump Starter -...
My dell inspiron 6400 won't start, red light then green light flashes ansd nothing happens, try to take out the battery and putting it back, no results, help
The following troubleshooting guidelines are basic troubleshooting steps. Battery Charging It is recommended to charge the battery while the system is off for faster charge times. Users may notice longer charge times when the system is powered on and running graphics extensive applications.
No POST If the system does not perform a Power On Self Test, there are various things to look for:
  1. Check to ensure that the system has a power light.
  2. If the system has no power light, ensure that it is plugged into AC power. Remove the battery.
  3. If the system has power but is not performing a POST, check to see if the keyboard status lights flash to indicate a successful POST, but no video, or that the keyboard status lights are lit in a sequence indicating a system problem.
  1. With the power off and the system unplugged, remove all CRUs from the system and reconnect that AC adapter to the system and try again.
  2. Run the On Board Diagnostics (OBD).
Video If the LCD on the system shows no display, or has other LCD problems, there are some basic steps to take:
  1. If the LCD is not displaying video or the video is garbled, run the BIST Test.
  2. If the LCD is not displaying any video, connect an external monitor to eliminate a no POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  3. Connect an external monitor when possible for all LCD related problems, to help eliminate a software possibility or video card problem.
  4. If the LCD has extremely dim video, attempt to adjust the brightness or connect an AC adapter to eliminate a power management conservation setting set in the BIOS.
  5. If the LCD has lines on the screen, check the system during POST as well as system setup to verify if the lines are present in all modes of operation. Run the BIST Utility.
  6. If the LCD has color problems, run the BIST Utility.
  7. Run the On Board Diagnostics (OBD).
Jul 19, 2011 | Dell Inspiron 6400 Notebook
Hp pavilion dv2500 won't boot. I can see some leds turn on but there's nothing on screen and no hard disk activity at all. What could be the problem?
itz may b caused frm many internal hardware cause, like the battery(main/cmos); ram; sm section of the system board; ccfl; inverter circuit; or even the lcd....
howevr, before proceeding to complex test to verify the current status of ur laptop, at 1st all u need is to put on the laptop to charge for atleast 4hrs..(the gauge status may show u a pseudo process)..
if u r a professional, remove the ram(s) from itz slot(s), gently rub itz connector teeth using a rubber to remove carbon or oxide formed if any..
connect it to a external monitor n see if display is coming..
check the internal system battery to b above +3v..
so itz always better to hv supervision..frm ur system admin/vendor/good or authorized service center....
Nov 13, 2009 | HP Pavilion dv2500t Notebook
Hear power on, black screen. wont do anything.
- try to connect you machine to an external monitor
- if the display appears on your external monitor the problem would be the LCD screen of your laptop (need to replace it)
- if there is no display on both laptop and external monitor i suspected it's the motherboard faulty
- send your laptop to service center to replace it (if it is underr warranty it's free
May 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
PLease help me with my Nokia 6288... Thanks!
hi there i have had that problem once, and i'v solved it.
for the heating of the battery and no lights, no display, no signal its all for the flex(ribbon) problem all i did was remove again the flex and clean the contacts sometimes it shorts i just re-solder the contacts of the flex. because some of parts that we bought is not 100% ok. just try it again maybe you'll make it.
ok
peace!
Mar 28, 2008 | Nokia 6280 Cellular Phone
Lcd display on my samsung fax machine model sf-360 is not working
Hi there there is no battery to replace it draws it's power from the power supply board. The only thing is that the LCD will need replacing as it is the complete control panel. You could try taking at apart and checking there isn't a dry point on the solder and re solder the LCD.
Try this but likely hood it that you will have to replace the control panel and in most cases this will out way the cost of the machine.
Hope this has been some help
Thanks J
Dec 20, 2007 | Office Equipment & Supplies
Fujitsu Siemens LifeBook E8010 Notebook Logo
209 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
