Question about Canon i455 InkJet Photo Printer
Print head missing message - Canon i455 InkJet Photo Printer
    Champion:
  • 219 Answers
Your prox switch has malfunctioned and might need to be replaced.
Posted on Oct 17, 2013
Why is print head loose or missing?
The print head houses the printer LASER if it is missing NO Printing. OR Loose normally the print head is located well inside the machine so you cant see the LASER beam when it is working.
Take the machine back to who sold it if the LASER ?PRINT HEAD is missing
Nov 15, 2015 | Kodak ESP Office 2150 All-in-One Inkjet...
Gives message Printhead loose missing or not installed. changed several times same message
If you already replaced Print head then same error occur their might be a problem with the carriage unit. kindly check also if there is a leak inks on a carriage contact then clean it.installed again print head.
May 08, 2015 | Kodak 6150 AllInOne InkJet Printer
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Why my printer say yellow cartridge missing,i replaced all of them
First thing I would do is to remove the yellow and put it back in, making sure it snaps in place properly. If that doesn't fix it you might be having a problem with the electrical connections on the print-head. Print-heads do act up sometimes. If it were mine, I would remove the ink cartridges and then remove the print-head and clean the electrical connections off on the print-head and the corresponding connections on the printer, using a alcohol wipe or something similar. Reinstall the print-head and ink and try it again. If that does not work you may need to replace your print-head. They are about 30-40 bucks online.
Jun 08, 2014 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
I have an ESP2150 with an error message of printhead loose or missing. I checked print cartridges, I replaced print cartridges, I re-installed software and drivers.....I still receive the same error...
Unfortunately, trying to diagnose a printer without actually looking at the printer is a little like trying to diagnose a car engine over the phone. But, from the sound of it, the problem you are having is not exactly pertaining to the print "cartridges" but the print "head" which is the part of the printer that actually introduces the ink to the paper, and is actually part of the tray the ink cartridges fit into. Here is a picture of it:
This print head is able to be removed and replaced if needed. It may be something as trivial as being loose. You can remove it from the printer and reinstall it to make sure it is seated correctly. Here is a link for instructions on Kodak's website on how to uninstall and replace the print head:
Installing and replacing print head.
If the print head is either damaged or worn out (which can happen) you can replace the print head, which I just did a search online for one and it appears the print head is only around $35.00 to replace it. Here is a link to where I found a replacement print head:
Kodak Print Head Replacement for ESP2150
I hope this helps.
-Nathan
Sep 26, 2013 | Kodak ESP Office 2150 All-in-one Printer
I'm getting an error message "Service required. Contact Epson."
Same story...Yes i use brand name cardrige... But i use it one a month since 29 months ! HELP !
Jun 04, 2012 | Epson Stylus R380 InkJet Photo Printer
Error message "head open" any ideas why please?
Check the microswitch on the leftside of the print head.
Sometimes a part is missing or the print head is not correctly mounted
Jun 15, 2011 | Toshiba TEC B-4700-I/O-QM Thermal Label...
My problem is I can't my any file print. the message coming error no 5200. How can i solved?
(1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working
Mar 05, 2011 | Canon Office Equipment & Supplies
My printer keeps rejecting new HP print cartidges. Now I get a message that the print head is damaged or missing.
If you look on the right hand side of the print head (the tray that holds the cartridges) you will see a grey lever. Try lifting and reseating that.
Dec 03, 2010 | HP Officejet 6500 Wireless All-in-One...
Canon i455 InkJet Photo Printer Logo
32 people viewed this question
old marine
old marine
