I have operated electronics shop in maduari some times i had lot of headache because customer purchased different and difficult type remote how can i have solved this issues.
It sounds like you're looking for a replacement remote control for your Aiwa Stack MX-Z9300m. Unfortunately, since your stack is an old model, it might be difficult to find a new remote control for it.
Here are a few options you can consider:
Check with Aiwa directly. Contact Aiwa's customer service and inquire about the availability of a replacement remote control. They may still have some stock of the original remote, or they may be able to provide you with information on where you can purchase one.
Check with electronics repair shops. Some repair shops may have the original remote control, or they may be able to repair or replace the remote control you have.
Check online marketplaces. Check online marketplaces such as eBay or Amazon for used or refurbished remote controls for your Aiwa Stack MX-Z9300m. Keep in mind that buying a used remote control may not be guaranteed to work properly, so be sure to research the seller's ratings and reviews before making a purchase.
Invest in a Universal Remote Control. You can purchase a universal remote control that can be programmed to work with your Aiwa Stack MX-Z9300m. These types of remotes are widely available and can be found at many electronic stores or online.
Consult the user manual or the technical specifications of your Aiwa Stack MX-Z9300m. You might be able to find information about the remote control that was originally used with the stack. With this information, you may be able to find an appropriate replacement remote control.
It's important to keep in mind that some of these options may not be an exact match for your Aiwa Stack MX-Z9300m, and may not have all the functions of the original remote control.
It's also important to check the Aiwa Stack MX-Z9300m's warranty status and the manufacturer's instructions to ensure that the repair or replacement will not void the warranty.
Your question is pretty broad, which makes it difficult to answer specifically. There are a number of different remote controls, many of which have their own lists of numbers that match them to specific pieces of gear.
This website: http://www.remotecodelist.com/ is a pretty good one for listing a lot of different remote types, and the corresponding lists of how to match them to your stuff. I hope this will help!
If you take it to a custom shop, they can quickly swap you out for a new module of your choosing. If you are handy and have a wiring diagram for the old module, you may be able to do the swap on your own. This is assuming the module is the only thing that needs changing.
If some problem exists in the wiring or the car, all bets are off. Electricity and electronics is not a forgiving field. Even if you are good with cars and circuits, a pro install shop would still be faster and much less of a headache.
This operates with a plastic card. You should get one of these from your bank, and activate it as instructed. They are typically used at an ATM, and you can also use it at a shop to make a purchase, which is called EFTPOS, You will swipe the card and enter your PIN code, and then you have made payment.
The remote must be programmable or have a feature called "Code Search". If the remote doesn't have these features then the answer is you will need to buy a remote like i described above with the ability to operate lots of different devices, they are really cheap for the entry level ones, less than $10.00, but I suggest you spend a little more and buy a higher end model with more ease of use features and the ability to operate more types of functions specific to a DVR or DVD or Blu Ray player.. Please rate my help for Fixya, it helps to show my expertise to others.
Almost any Mitsubishi remote made in the last 8 years will operate this set--even the ones for the DLP type sets--stay away from universal remotes as most of the time the will do only the basic functions---I have talked to customers of mine who found used ones at swap meets etc for very little money---I would bet you can still get the remote from Mitsubishi--if I remember most of these are around 40 dollars from them.
Another idea is have someone at a TV shop look at your old remote--if they know what they are doing they can test it( I have a laminated card with a strip on it--point the remote at the card and the strip should light up when you press any button)
If if cannot be fixed---Try either Mitsubishi or I have seen a lot of these remotes for sale on Ebay.
Let me know if this helps you-----I am here to help people.
Take your existing defective remote to an electronic shop and ask for a new remote of the same model or equivalent and you could buy one across and it is not a difficult issue at all!
Contact Emerson Electronics customer service to acquire a replacement remote for this set, as this set does not have the extensive circuitry inside to duplicate the functions of said remote...accordianman
