Question about Whirlpool ADG75601 Builtin Dishwasher
Whirlpool ADG7560 - lights on when door open, they all go out as door approaches shutting! Connection problem? When lights on, selection not working either. Machine stopped mid cycle and full of water.
    Master:
  • 492 Answers
The is a loose connection to the power somewhere. Recheck to see if there are any loose wires to the circuit board or door switch.
Posted on Oct 17, 2013
Whirlpool adg7560/1 can't attach fitted door
The square bits should be inserted into the large opening of the keyhole slots and slid down into the narrow part. This probably has to be done as a single operation with all square bits aligned with the large openings before the strip is slid into place.
Nov 07, 2013 | Whirlpool ADG75601 Builtin Dishwasher
Whirlpool dishwasher adg7560 troubleshooting The
> broken wire.
>> call the service agent
Oct 17, 2013 | Dishwashers
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
I've got a Whirlpool side by side refrigerator that is about 7 years old. The freezer side works, the frige side works, and the ice maker is making ice. The front door ice and water dispensor isnt working...
That will take a few test to determine which is the most likely. Most times it is a loose connection in wiring harness as it goes from cabinet to door or the freezer light switch is defective. When you open door to freezer all of the fountain and ice maker power is disconnected for safety reasons. If the switch is defective when door is shut then these are acting as a lockout. But you just said ice maker works so we are back to a bad connection or the LV (Low Voltage)board itself. This will take someone with a multi meter and follow through with me and wiring from the tech. sheet. I will try to make a wiring diagram for you to follow here. Thanks, Sea Breeze
Jan 19, 2011 | Whirlpool GD2SHGX Refrigerator
Hi, my whirlpool ADG7560 dish washer does not have any water passing through the spray nozzels, they are all clean, could this be a pump problem? the machine is only 3 years old
Yes , if the pump under the spray arm is broken and not spinning with the motor it won't spray. Need a different model number for more help.
Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 21, 2010 | Dishwashers
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Machine stops, "door open light" flashes door is securely shut.
bad door lock and or harness replace door lock assy and check all connections
Jul 07, 2009 | Washing Machines
Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Dec 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ADG75601 Builtin Dishwasher Logo
90 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
