SOURCE: Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
it might be too small of a fuse for your machine
SOURCE: why does my washing machine trip the electric
Someone with a wattmeter needs to read the wattage load by the machine when washing. If the running load is greater than the rated load of the machine, then the problem is likely the motor itself or the drum bearings are going bad. If the electrical load is normal, then the breaker in the house electrical panel is either under-rated, or the breaker is defective. If the breaker is a 'ground fault' type, the washer may have current leakage to ground causing the breaker to trip. Another possibility is that there is another outlet that is on the same circuit and the combined load trips the breaker. Shut the breaker off and try any other sockets in the area to see if they went dead too. Hope this helps!
SOURCE: Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
