Question about Toshiba (K000006610) for Satellite P25 Series Motherboard
Monitor keeps going to power save mode
I connected a monitor to my laptop and it keeps going to power save mode. How do i turn power save mode off?
  • Anonymous Nov 06, 2007
    my computer is in power save mode and my screen keeps turning black. What do i do to fix this
  • Marcus Blake Jun 17, 2008
    When I installed windows xp professional program to my laptop, my external plug and play dell monitor went into power save mode and will not come out. The main problem is that my laptop screen is broken so my external monitor is the only monitor that I can read from. Please help. ([email protected])
    President:
  • 2,961 Answers
The settings should be the same as your notebook power saver settings or you will have to check extended monitor in your graphics card properties in control panel.
Posted on Sep 26, 2007
SOURCE:
Power Save Mode & PS3
restart the computer HOLD the keys CTRL+ f11 or f12 depend from you mark, and go to restore factory defaulty and ready.
God bless you
Jun 23, 2013 | Computers & Internet
Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Analog power saving mode
If its going to analog power saving mode, that is what its supposed to do when it does not get a recognizable connection from a computer vga port. I would suggest coming back on with some more information about your computer and suggest testing another screen on your pc.
Oct 31, 2009 | LG 22" FLATRON LCD Monitor
Power saving mode
Prevent the laptop/desktop monitor from going to power saving mode:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 04, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
    LG LCD Monitor L1530S problems
    Most screens will show nothing or go to power saving mode until the PC is turned on. The monitors need a signal in order to be 'active'.
    From your description it could just as well be a problem with the PC rather than the monitor. The easiest way to find out is to connect another PC or laptop to the screen or connect another monitor to the PC unit.
    Did you try pressing the Del key or F2 key when you turn on the unit to get into the Bios?
    Jules
    Jul 16, 2009 | LG L1530S 15" LCD Monitor
    How do we turn off the POWER SAVING MODE on the monitor screen?
    Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
    Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
    MY DELL SE198WFP GOES TO POWER SAVE MODE AFTER 2 SECONDS
    I had this problem as well as a lot of other people. The solution is to go to the power options in the control panel and turn power saver off. This should keep the monitor from going into power saving mode.
    Dec 29, 2008 | Dell SE198WFP LCD Monitor
    Monitor
    -Turn off both computer and monitor
    -unplug monitor from computer(still plugged into power supply)
    -turn on computer and monitor(monitor is still unplugged)
    -After computer is on for about 30 sec. plug monitor into computer
    -turn off both monitor and computer(now connected together)
    -turn on monitor then computer and should be good to go!!!
    Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
    Computers & Internet Logo
    3,149 people viewed this question
    Top Toshiba Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
