Question about Microwave Ovens
Polti Vaporella 600 not pumping tested pump OK so either main PCB or Reed switch Fault ? Bridged reed switch no go No LED's lit on PCB power running at 240v any ideas or wiring diagrams for PCB Please ?
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Wiring diagram will be difficult. You must search on internet by try to get some one.
You must test the input voltage for to see if there are voltage, test the fuse or c.breaker for open or faulty and replace or repair. and try again. However will be a Great idea, if your Resolder all the colder union PCB from oxide,bad contacts.etc., and try again.
God bless you
Posted on Oct 17, 2013
4 Suggested Answers
banar
  • 26 Answers
SOURCE: Whirlpool MH6151XHT-1 - No Power - Stumped
First change all the fuse and check whether it works or not, if it does not work than as per your finding the secondary transformer could be the issue, the secondary transformer tap down the voltage fro 230-240/110 to required control board voltage. the best thing if the unit is opened then the right problem can be found but as per your description either fuses are faulty or the secondary transformer.
Posted on Dec 12, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: No lit LED, No panel control. Vent fan, running
We regularly repair these control panels for customers nationwide with our guaranteed $39.95 service.
Full details of our service are at http://www.microwavedisplay.com.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Posted on Sep 06, 2008
  • 5 Answers
SOURCE: i have a polti steam
Steam irons are built to run on tap water, there will not be any problems whatsoever unless the water is hard, which may leave sediments inside the iron after evaporation.
Posted on Feb 28, 2011
My microwave has no power,I have checked all fuses, switches and thermostats, i've replace the main control pcb. still no lights or display
pwr comes in, goes thru fuse to transformer which powers pcb and mag. pcb is not getting pwr. chk ur installation and the output from the transformer
Jan 25, 2016 | Microwave Ovens
Runs when door is closed,stops when open!Checked the three door switches;all good.The mw is 5 years old so anyone have suggestions as i would be thanking U in advance
It is possible that a relay on the control board has stuck in the closed position. You can try tapping the relays on the main control board and this sometimes breaks them free. It still may be one of the door switches but I would suspect the control board or possibly a stuck start pad on the touch panel.
Apr 24, 2015 | Cuisinart CMW-100 Microwave Oven
I have a NNSD297 Panasonic over the range microwave oven. First the unit had power, clock , timer, fan was working; except after hit the start button, maybe 2 secs looked like working then stops operating....
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Feb 11, 2013 | Panasonic Microwave Ovens
Krups XP7200: when I turn it on, after a few seconds all LED flash and error code 3 is displayed. Nothing can be done
The fault can be related to the program controller, so check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Aug 24, 2011 | Microwave Ovens
I have a polti steam iron 600 do i have to use distiilled water or will tap water be ok thanks
Feb 28, 2011 | Microwave Ovens
It always say F7
HI. This is, essentially, a inverter fault error cofe(F7). This code will indicate that there is an electrical circuit malfunction located at the L1 an neutral junction point on the main inverter board, itself. I will post a quick check point list below to guide you through the necessary troubleshooting that is needed at this time. If all check points below check out ok, simply replace the inverter board.
Check Points:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check the thermal fuse for the magnetron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If removing power for that length of time solves
the problem:
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Verify that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace the main control PCB.
Dec 02, 2010 | Whirlpool MH2155XP Microwave Oven
My microwave kenmore 66222500 makes a humming sound like if it was on when the door is closed. i have to unplugged it or leave door open to stop the humming sound. I tested the magnetron, the primary and...
Possibly a shorted relay on the main timer board?? hum coming from transformer being powered with no fan running. With No fan you can hear it hum. shorted power relay on main board.
Jul 28, 2017 | Kenmore 68361 Microwave Oven
The turntable on our Whirlpool VT256 oven has
it could be 1 of 3 things here 1 the coupling under the plate mat be warn or broken inside so the shaft of the motor maybe turning but not turning the plate take the plate out and put a cup of water in the unit and see if coupling moves without the plate if not thn see if you can remove the coupling and repeat the test if you can see the motor shaft moving thn u need a new coupling, if not thn you may need a new motor to test th motor you will need to turn the unit on it side remove the plate first on the underside on the unit round where motor is you will see a plate this will round or square you need to cut this away to expose the motor dont throw it away as you need to refit if after, it turns round and you screw it back on, when you have found the motor remove and replace it albeit the motor is powered by the pcb it is unlikely to be the pcb as the motor runs all the time so they do ware out also do look to see if your unit has a turn table switch off button on the controls or in the manual hope this helps and dont forget to unplug ur unit from the mains.
Oct 17, 2009 | Microwave Ovens
Microwave start and after a few seconds it shutdows
That is typically a bad mag or a bad inverter. Sort of pricey either way. Hard to test the inverter without a good mag and running the unit and testing the amp draw. I repesented Panasonic and stopped doing warranty service for them because of that Inverter System. The inverters fail so often and are a bear to confidently diagnose. Sure there are tests at certain points you can do, but you really cannot difinitively test the mag without just applying the proper voltage to it and see if it fires. For the cost of new Microwaves today. I personally would RUN! There are tracer signals that must go from the main board throught the inverter system and back to the main board. If something interferes with that is will shut down or give you a code. So Ultimately it could be MAg, Inverter, or Main PCB, not worth it. Get a new unit with full warranties and be done with it. You will save money in the long run.Good Luck!!
Aug 14, 2017 | Panasonic NN-T655SF Microwave Oven
William E. Miller
prototech@usa.net
Aug 14, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
