Usb port not working on dell latitude E6430s - Computers & Internet
Pyrhyc
  • 2028 Answers
SOURCE: replace broken usb port on dell latitude laptop
You will have to take the machine apart somewhat, or at least to the point of being able to disconnect and remove the usb port. Here's a link to the D600 service manual download. It will guide you through the breakdown process.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Posted on Jul 27, 2008
nanbuenbrazo
  • 553 Answers
SOURCE: THE USB PORT OF Dell Latitude E6400 IS NOT
have you upgraded your OS(operating system)?
If you do, you must find a UISB driver that will support your new OS
Posted on Nov 05, 2009
  • 357 Answers
SOURCE: Dell Latitude 630 docking station USB ports no longer work
Try removing the laptop, unlug the power to the dock and wait a few minutes, then connect the power now put your laptop back on the dock.
I hope this helps.
Have a good day and good luck.
Posted on Nov 20, 2009
  • 14 Answers
SOURCE: DELL LATITUDE D600 USB PORT NOT WORKING
You can solve this issue by installing usb 2.0 driver in your DELL LATITUDE D600 laptop find Blow Drivers Download Link:
.DELL LATITUDE D600 Drivers Download Link
Posted on Feb 05, 2010
  • 1481 Answers
SOURCE: My Dell Latitude D400 laptop's USB ports stopped
USB port is corrupt...if all that you said is what is happening then the best is to
buy a keyboard to USB port convertor....
refer this image....Ebay has it for about 1$
Posted on May 10, 2010
Smoke came out from the back after I tried to replace LCD monitor in my Dell laptop E6430s
be sure you had installed a compatible LCD on your system. take out all the connection of the lcd and try to figure out where the smoke came from, in might be from the inverter or from the supply.
thanks
Apr 01, 2014 | Dell Latitude E6400 Notebook
Dell Latitude C840 issue. Have 4 input USB 2.0 PCI card adapter that is connected to side USB 2.0 serial port, but external HD and devices are still running at 1.1 speed (as if I plugged into the back USB...
Hi, I haven't got a Dell but try this site for the USB driver that is missing. With XP there is no support for USB2, an updated driver is required. Did you download the drivers from Dell? If not, that could be why as they may be old drivers.
Oct 29, 2013 | Dell Latitude C840 Notebook
My Dell Latitude D400 laptop's USB ports stopped working. They used to work fine, now they don't recognize anything (card readers, mouse, camera, etc.) I removed the USB port drivers and reinstalled. It...
May 10, 2010 | Dell Latitude D400 Notebook
Feb 05, 2010 | Dell Latitude D600 Notebook
USB PORT NOT WORKING.
Both USB ports use the same driver, so if one works and one doesn't, you have a mechanically bad port. You'll need to replace the hardware to solve the problem. There are usually a lot of bad D600 motherboards on Ebay. Or try to find just the USB port you need. Fairly simple replacement task, but laptop dis-assembly will be required to reach the part.
Nov 12, 2009 | Dell Latitude D600 Notebook
ONE OF MY 2 USB PORTS DOES NOT WORK ON MY DELL LATITUDE D600. I TRIED THE FOLLOWING FIX, >START>RUN> DEVMGMT.MSC AND UNINSTALLED ALL USB CONTROLLERS, RESTARTED MY LAPTOP (WITH WIN XP PRO) WHICH...
Hi Roger,
The Windows command you used to uninstall the USB port is correct. If they all work bar one, then i think its safe to say it's possibly a hardware issue.
The only other fix i can think of is to update the BIOS with the latest version from the Dell support website.
Good luck.
Dell d600 usb ports not working
There's only one USB port on the c600
Oct 11, 2009 | Dell Latitude D600 Notebook
XP crashed on my Dell latitude D600 laptop. I
go to mfg websight and down load all th proper drivers there is likely a mother board driver not installed that allows it to see the ports
install all of the manufacturer's drivers
dont expect that microsoft wrote windows just for your computer it is a general set of generic drivers that make most things work but not every thing
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
Aug 03, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
The usb of my dell latitude c400 notebook is malfunctioning
Unfortunately, I have seen this many times. One of the major problems with the C400 model was the USB port failing. I have had many of them replaced under warranty, and I have repaired some. The USB port breaks loose from the mother board and stops working. It is possible to SOMETIMES disassemble the laptop enough to get to the port and re-solder the USB port connections. But is is a slow process for experienced people. And it does not work all of the time. i know that this is not the answer that you wanted.
Good luck with it.
~ Spoem
Mar 18, 2009 | Dell Latitude C400 Notebook
Replace broken usb port on dell latitude laptop
Jul 27, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
