Question about Philips Norelco 8175XL Electric Shaver
Remington PG-200 is stopping even when well charged. It has been a great little trimmer and since i have a little hobbyist enthuusiasm in repair. The worst is that I would have to replace it but I would rather fix it myself as it is just out of warranty now tha just replace it. anyone familiar with assembly/disassembly of the Remington-PG-200 Trimmer?
Charger cable for remmington pg-400
You will find the charger at shaveroutlet.com using the link below
http://shaveroutlet.com/remington-charging-cord-for-pg-250-and-wpg-250.html
Jun 22, 2014 | Remington High Precision PG400 7in1...
Remington pg200 groomer disassembly
This is a very simple repair.
To disassemble, twist the round bottom part (with the battery contacts) counterclockwise just a bit. Use jaw pliers if it won't twist with your hands alone. To protect the plastic finish of the groomer use some duct tape or a rag on the jaws. Gently twist and open the assembly. When separating the bottom part, take care not to pull it apart too far from the main assembly to avoid damaging the 2 thin wires connecting the bottom plate on the inside of the bottom charger to the main body of the groomer. The batteries will just slide out easily; they are not soldered or attached in any way. You can replace the batteries with any two standard AAA rechargeable NiMH batteries (1.2 volt).
Since the batteries are so easy to access, and there is no solder involved, in a pinch you can even use regular AAA Alkaline batteries! (but, of course, NEVER USE THE CHARGER WITH NON-RECHARGEABLE BATTERIES!!)
The groomer is now as good as new!
Dec 08, 2012 | Remington Precision Deluxe PG-200 Beard...
Reg Remington Model PG-250
Send back to manufacture. I have 2 and i had to call remington to order the replacement microsreen. very hard item to find replacent parts for
Feb 23, 2008 | Health & Beauty
Battery Replacement for Remington PG-300 Beard Trimmer
Hi
The manual will give you info on the battery that is inside the trimmer.If you can get to the battery then buy same TYPE or similar to the original---VOLTAGE/CURRENT RATING/CHARGING etc and size, connection
Hope this helps
Jay
Nov 17, 2007 | Remington Titanium Precision PG-300 Beard...
Trimmer Not Charging - No CHARGE Light too.
I have the same problem using Remington MB 200
Aug 30, 2007 | Remington MB-300 Beard Trimmer
Philips Norelco 8175XL Electric Shaver Logo
27 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
