Question about HP LaserJet 5100tn Printer
79.060e error machine displays that error and does not work
  • Anonymous Apr 14, 2008
    duh... what's a "DIM"?
Turn the printer off, then turn it back on.  This solved the error for me.
Posted on Jan 23, 2009
Remove all dims or third party dims from the printer,istall them one by one not forgeting to turn the printer off and back on as u install each device replace the one that causes the error.
Posted on Sep 26, 2007
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: 79 error displayed power on power off and the
Hi
I can only say try it may work.
A solution:
  • Unplug
  • Hold down "*" & "enter/ menu buttons"
  • While holding down both buttons, turn power on
  • Wait until something like "initialize" shows up on the display
  • Let go of buttons
  • Wait until display reads "ready"
  • Unplug for 10 seconds, then plug back in
  • Please let me know if works for you.
  • All The Best Pineworks
Posted on Jan 30, 2010
Came up on display f10 and wont work
Hi dear,
F10 error related to OVER FILL. Follow the things below,see how it works.Thanks.
Troubleshooting
Error messages If an error occurs during the program, a message
is shown on the display. To exit the message after
taking action, turn the machine off and then back
on.
The error messages that may be shown in the
display are:
F10 Overfilling
1. Shut off the water tap.
2. See "Drainage error".
F11 Drainage error
Check:
• that no objects are stuck in the drainage hose
outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump. See the "Care and
maintenance instructions" chapter.
• that there are no kinks in the drainage hose
After taking action, run the Drain program or press
the Door Opening button (key symbol) to empty
the machine. If this does not resolve the problem,
call the Customer Care Center.
Jan 27, 2016 | Asko Washing Machines
Electrolux EW1087 with error code e91
Communications error between main PCB and display board.
Possible causes: wiring, main electronic,display board.
Dado
Jul 26, 2014 | Electrolux Washing Machines
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
Machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
May 27, 2009 | Hotpoint Ultima WD72 Front Load...
Machine Error e1-20 is being displayed after copier was moved.
That error is related to the laser unit. Check your connectors, they may have vibrated loose during move. These machines have a history of laser units going bad.
Apr 15, 2009 | Panasonic FP-D250F Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Error... the Fiery Server Interface timed out, please, check the Fiery
Sir, I have Document Centre ColorSeries 50 In this machine Scanner is not working, in the Machine Display showing : Error... the Fiery Server Interface timed out, please, check the Fiery. Please help me
Sep 24, 2008 | Xerox DocuColor 12 Color Copier
HP LaserJet 5100tn Printer Logo
1,934 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
