Question about Verbatim Computers & Internet
Repair usb flash drive - Verbatim Computers & Internet
  • Verbatim Master
  • 27,725 Answers
Which operating system ?????....
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
You might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system.
if you need more help with this or if i have missed the problem post a reply
Posted on Oct 18, 2013
Hwo to format my usb falsh drive? http://www.usb-drive-china.com
Just click right click on the flash drive , then click format ,choose the files system either Fat 32 or NTFS then quick format then start , look to this picture
If not formatted so you have a problem with your flash drive , learn how to fix it by reading this article
How to remove write protection on flash drives
or
How to repair corrupted usb flash drive
Dec 09, 2013 | tradetang.com
Repair
It may be broken, but I've found that you can get a repair for a non-appearing pen drive by using the wonderful software called photorec bundled in the testdisk software.
(http://www.cgsecurity.org/wiki/TestDisk_Download)
Jun 13, 2013 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Read-only files and how to them?
Possibility
Firmware flash drive corrupted (the disk is write protected).
Solution
To repair damage to the firmware, the solution can be found on google seach engines. Example; Fix transcend flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
Dec 15, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My trancend 8 gb has become write protected. I used the regidit formula but the problem continued
Flash drive is write-protected, meaning there is damage to the firmware. To repair damaged Transcend firmware, use JetFlash Online Recovery software.
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download)
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
I hope this information helps.
Before repaired
After repair
Oct 06, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a transcend jet flash v33 4Gb. I save files in it and then safely remove it, the next time i access the file it is already corrupted. I tried to format the usb but it still have the same problem....
Cause of damage is bad sectors
Transcend repairing bad sectors, you can see my blog.
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". View the the video tutorial "Repair Transcend Bad Sector"
Hopefully this information helps
Oct 02, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb thumb drive repair
Hello my friend
Here is a link how to see if you usb is been recognized
http://kb.sandisk.com/app/answers/detail/a_id/10/sno/0
And here is a link to download drivers for your usb
http://www.sandisk.com/sandisk-support/driver-download-wizard
Jan 14, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My transcend jet flash drive is not detected on system. details are as follow:Transcend jetFlash RV10 8gb
Hi friend,
Your trnscend jet flash drive is damage so you need to contact nearest hardware service centre they will repaire it ...
Jan 06, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to repair a malfunctioning usb flash drive that is not showing up on my computer, with out losing the files.
for your info, damaged usb flash drive cant be repaired.
some pendrive data can be repaired by the expert, and usually only the manufacturer expert, but it will cost you a lot of $$$....
if you still struggle for the data inside the flash drive, just contact directly to the manufacturer.
If the flash drive still on warranty, i can guaranteed  that you will get a new one.... :p
posted by cj-skynet
Jun 13, 2009 | Electronics - Others
My computer wont detect my USB flash drive
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Nov 24, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
Computers & Internet Logo
67 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
