Question about Dynalon 540004 Merit Water Purification Still/Laboratory Water Distillation Stil, 220/240V, 50 - 60Hz
I want to get a procedure manual for this equipment
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
I have to change my both timing belts on my 308 gtb quatrovalve 1983 ferrari. i live in trinidad, and there are no ferrari mechanics here. is there a step by step procedure for this..
The factory manual has directions, some of it is overkill, but this procedure is an engine out service and requires more shop equipment than most people have, A shop with reasonable equipment can complete the procedure but, one notch off and your engine will be no better than a boat anchor.
Nov 03, 2010 | Ferrari 308 GTS Cars & Trucks
I ran the self-cleaning and the door will not open.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Mar 06, 2010 | Whirlpool Ovens
I have a 2150 poulan that wont start. gets gas and spark plug fires
Read your manual cold start procedure carefully, especially the second note. IMO open the chock (not 1/2) once it tries to start and I think your problem will be solved. Try this start procedure I think it works better than the one in your manual.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed or 1/2.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
I am going to close this. If no better post back (below) and we will get into some trouble analysis. Yours is a better than normal question, Thank You
Lou
Feb 21, 2010 | Poulan Garden
How to unlock my door after self cleaning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Jan 26, 2010 | Maytag MER6772 Gemini Electric Kitchen...
FGE30655KF SLIDE IN--How do we unlock door.
or
Dec 11, 2009 | Frigidaire Ovens
I need to get my oven unlocked. The cleaning cycle went haywire
or
Oct 25, 2009 | Whirlpool RBD305PD Electric Double Oven
Door wil not open after self-cleaning cycle.Code
or
Sep 18, 2009 | Kitchen Ranges
Oven door is locked and we can't open. We have tried everything including turning off the circuit breaker several times. HELP please!
or
Sep 12, 2009 | Kitchen Ranges
Dynalon 540004 Merit Water Purification Still/Laboratory Water Distillation Stil, 220/240V, 50 - 60Hz Logo
392 people viewed this question
Top Dynalon Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Dynalon Science and Laboratory Expert? Answer questions, earn points and help others
