Teka fc1350 Unable to stop fridge freezing with temp control
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Need to know the model number to see if the unit has a
circuit board thermostat or a mechanical thermostat.
If it's mechanical then the thermostat is bad and needs to
be replaced.
If it's electronic then either a relay on the board needs replaced
or the entire board. Which isn't cheap.
Posted on Oct 17, 2013
Testimonial: "Thanks unable to get to back of fridge"
Teka fridge freezer lightcome on but not working
2 common issue's
1. check power going to compressor (rear).
if there is power, you have no gas or faulty compressor.
If NO power to compressor, check
2. temp stat, (it's just a switch, controlled by heat/cool) turn off power and link the two wire's together.
turn on power and listen if it has started to run.
If Yes, DO NOT RUN. put back to they way it was and replace with new stat.
If No. call an engineer, WARNING a new fridge freeze might be cheaper.
Nov 24, 2014 | Refrigerators
I need a manual for a teka a-fc1350
Goggle to find out the company that built it and see if they will send you a copy or if its available for download. This is a common problem with private sales without all the manuals that come with it. Sometimes you have to look up each appliance or model. Start with a phone number to the manufacturer and work from there. Also you can find someone that is selling one like yours and call them to see if they can send you a copy from their manuals.
Oct 17, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Teka freezer
need model number but most Teka models have integrated controls and a compressor system that is shared between freezer and fridge. so it looks like you cant isolate one or the other.
if you provide your model number then it might be a special case. here is user information on one model Teka.
http://www.fridge-manual.com/teka/teka-tki2-325.html
Oct 02, 2013 | Jenn-Air Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
The top part of the refrig keep freezing?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Apr 14, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Washing Machines Logo
Top Washing Machines Experts
