Error modem connecting device already connected not configured properly windows 7
    Champion:
  • 219 Answers
Reconfigure device and you might want to try a hard reboot on the wireless
Posted on Oct 17, 2013
4 Suggested Answers
  • 4 Answers
SOURCE: Modem are not connect in reliance netconnect
if you can, remove and reinstall the modem and/or the program.
look at the cable fittings and see if something is broken or bent.
try your local geek network online.
go to your usb port settings and see if it is reading the proper link to your modem and see if your modem is recognized.
may be the network settings you have. in conflict with your modem and network router.
Posted on May 24, 2008
Geekman
  • 32281 Answers
SOURCE: modem problem
Disconnect the phone line from the modem and connect a normal phone to this phone line. Lift the handset and check it you have a dial tone and see if you can dial out.
If you don't get a dial tone then there is a fault with the phone line and it needs to be repaired before you can use your modem.
Posted on Apr 14, 2009
TheSelkie
  • 734 Answers
SOURCE: toshiba laptops a30 error 633 the modem or other
Since you don't list your operating system, its hard to take you through all the arcane steps that don't always solve this problem that has caused many people alot of grief. So, here's something you can try if your laptop is no longer under warranty. These were badly made modems that get loose in their plugin spot on the motherboard. You can remove the cover on the bottom of the laptop where the modem is located and fold a small peice of paper ubntil it's the right thickness so that when you set it on top of the modem and screw the cover back down, the cover pushes down on the paper and thus the moden causing a tight plug in fit.
If you don't understand what I'm asking you to do, don't try it yourself but find a friend who's familiar with opening up laptops to do it with you.
It may sound nuts but it works a fair bit of the time. If it doesn't work, you'll either have to do some fairly advanced software adjustments or buy a new modem. This error code number you're getting often means the modem is bad.
Posted on Jul 13, 2010
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Internet connection error 734 extra initialization command does not work.it leads to another error 692.
692 - Hardware failure in port or attached device.
This behavior can occur if any of the following conditions exists:
  • The modem is turned off or malfunctioning.
  • If you have an external modem, the serial cable is incorrectly wired.
  • If you have an external modem, the serial cable is not securely connected or has open connections.
  • The serial port or multiport adapter on the RAS server or client is malfunctioning.
  • The handshaking options for the modem are incorrectly configured.
  • The modem is unsupported, or the chosen emulation may be incorrect.
  • The modem .inf files become corrupted or the modem driver becomes corrupte
To solve this problem, use the appropriate method:
  • Reset your modem. Consult the documentation for information about how to reset the modem.
  • If you have an external modem, make sure that you are using the correct serial cable. For more information about requirements for proper cabling, refer to the "Cabling Requirements" section in Dial-Up Networking Help.
  • If you have an external modem, make sure that the serial cable is connected securely.
  • If you are using a pin adapter to connect your external modem to your serial port, make sure that the pin adapter is wired properly for modem communication. For example, a 9- to 25-pin adapter for a mouse does not work properly with an RAS serial setup.
  • Test the serial port or multiport adapter, and replace the adapter if necessary.
  • Make sure that the handshaking options for the modem are configured properly. Consult the documentation for information about the different handshaking options that are available for your modem.
  • Contact the modem manufacturer to see if any setup and initialization information is available for your modem. Also, check the latest Windows hardware compatibility list (HCL) to make sure that your modem is supported.
  • Use Device Manager to remove the modem. You can do this in safe mode or in normal mode. Restart the computer in normal mode. Windows will redetect the modem and reinstall the correct drivers.
May 12, 2011 | Computers & Internet
I have Cricket broadband and i get disconected very often and when i try to connect i get this error message: The Modem (or other connected device) is already in use or is not configured properly. The only...
Hi Ramon,
My name is Ryan and I work on behalf of Cricket. Please call Cricket Broadband Customer Service Center at 1-800-CRICKET and select Option 2.
*Before contacting a Customer Service Representative, please ensure you have the following information:
-Operating system (i.e., Windows X...P)
-Cricket Broadband Modem Device number (MDN) assigned to your wireless modem
Best,
Ryan on behalf of Cricket
Jan 30, 2011 | Computers & Internet
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
Error 633
right click on my computer and go to properties then hardware in that click on device manger and choose the modem option just expand the list it will show the modem which you installed just right click on it and got to properties and choose the diagnostics option and there is one tab down query modem it will communicate with modem if you find the character or response that means modem is correctly installed or if it is not that means you need to re install modem driver.
Sep 17, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
Connecting to Internet using a dial-up modem
can you connect that modem first, to a phone line, and run a telnet or dial connection from control panel or accessory ?
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
