Recently got a bush a126q washing machine. It now only fills partly with water then does nothing and then ends the cycle. What is wrong?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
If this is a top load washer then I would start with the
door safety switch. Check with an ohm meter. Open
would be infinite ohms. Closed would be a short.
Next would be the water level pressure switch. I usually
take the hose off of it and put another hose on. Then I
blow into the hose and listen for a click. You can also
use an ohm meter to see if you're making contact.
Next would be a costly circuit board.
Posted on Oct 17, 2013
Master_Tech
  • 770 Answers
SOURCE: Water Does Not Drain
You may need to Clean out the pump catch to do this you need to remove the drain pump access cover, insert a pointed object (or tool) into the hole, Bottom right front of the unit push in to release the latch and rotate the cover clockwise.
you will need to clean this out use a shop vac to remove the water in the unit or have plenty towels handy
AS far as the fault code
E:04=Er:04washing=Door control broken
Cause=Faulty Triac or control module
Posted on Feb 17, 2008
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • 1028 Answers
    SOURCE: my hotpoint washing machine doesn't stop filling up with water
    remove front cover by sliding putty knife along top edge and pressing down on clips pull front off ck small hose attached to tub on left side look for a dark build up in tube pull off and clean..blockage will cause water level switch not to sense full tub of water..if tub just never fill ck drain hose for correct height from floor and loose fit in standpipe
    Posted on Dec 22, 2008
    • 44 Answers
    SOURCE: Washing machine tripping RCD
    electrical short in m/c.could be heating element. regards
    Posted on Jul 30, 2009
    • 512 Answers
    SOURCE: water will not shut off in washing machine
    Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
    Posted on Aug 18, 2009
    My Bush A126Q will not spin at all. I have cleared out filter and wastepipe.When i start a cycle it makes noises and looks to fill with water but drum does not move? Is there a way to reset machine?
    The only reset is to unplug it from power for a few and then see if it resets, if not then you need a service technician to come take a look.
    Jan 31, 2017 | Washing Machines
    Washing machine stops before rinse cycle
    have you checked on the machine internally if you have a borken fuse near the control board of the washer? many times, of age, this part can be rusted and damaged, thuis needs replacement on some parts, and cleaning on most part.
    what is the exact model of your wahser, so that we will be able to provide a diagram on where you may check the issue.
    Sep 16, 2008 | Washing Machines
    Bosch washing machine fills with water throughout any cycle
    Just a guess but could the fill valve be defective, not shutting off completely when it should?
    Nov 21, 2013 | Bosch Washing Machines
    Hi, recently bought a bush a126q washing machine, worked perfectly fine after 2 washes. However, firstly the programme starter light doesn't stay on throughout the wash, is this a problem? Then the washing...
    Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board. It's like rebooting your computer. I did this to mine and it cleared up the problem.
    Oct 16, 2013 | Washing Machines
    Reset switch Bush A146Q
    MY ON/PAUSE BUTTON IS BROKEN ON A126Q /A146Q model. i do not want to have to buy a new machine, where can i get this part?
    many thanks,
    Jul 29, 2012 | Washing Machines
    My bush washing model no:a126q will not start
    Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
    I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Sep 15, 2011 | Washing Machines
    I've just had a bush a126q washing machine delivered but the delivery man could not install it because he said our cold water pipe was not working. The other machine that we are replacing just had a...
    it will work fine but the problem is that all the rinses will be done with warm water, this causes seriously wrinkled washing thats v hard to iron out.
    Jul 06, 2011 | Washing Machines
    What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
    hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
    Its looks pump dont work //////
    Please advise me what to do ???????????
    Thanks
    Mar 19, 2011 | Washing Machines
    How do I open the door to my Bush a126q washing machine after a quick wash?
    Reset it back to the spin cycle and try to empty some more water out of it. It should release the door when it knows it is empty.
    Dec 05, 2010 | Washing Machines
    Bush A126Q White and the ''end of programme'' light is staying on
    Sorry Jo, I think I may have mis-understood your explanation - is there actually a problem with the machine functioning properly or is it simply that the end of cycle light will not turn off?
    If it is the latter then simply turn the dial back to 0 before opening the door from the previous wash, this action tells the washing machine to reset itself as the drum is about to be emptied.
    I have the exact machine however as it is graded, it didn't come with any manuals, at the end of the wash I just figured thta this was what I needed to do.
    Its almost as if you need to double-declutch the washing machine - return the macine to 0 before selecting another cycle.
    Feb 03, 2010 | Washing Machines
    Washing Machines Logo
    104 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
