Question about Dell Vostro 1450 USB Docking Station Targus ACP51USZ $119
Error modem connecting device already connected not configured properly
Geekman
  • 32281 Answers
SOURCE: modem problem
Disconnect the phone line from the modem and connect a normal phone to this phone line. Lift the handset and check it you have a dial tone and see if you can dial out.
If you don't get a dial tone then there is a fault with the phone line and it needs to be repaired before you can use your modem.
Posted on Apr 14, 2009
bronk50
  • 27725 Answers
SOURCE: Modem problem
make sure all connections are right USB or ETHERNET and youre internet service provider settings are correct or possibly disable your firewall until you get a connection
Posted on Jul 27, 2010
rommelalilin
  • 2178 Answers
SOURCE: I have a Dell Inspiron
Try another access point from a neighbor or a friend who has a wireless network and log in with there permission (you'll need their network number) - the problem might be your home network modem. Sometimes the bar are miss leading and not necessarily accurate.
Posted on Dec 06, 2010
puertobori
  • 7733 Answers
SOURCE: hello im troubleshooting a error on a dell
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Posted on Jan 06, 2011
shibuda
  • 1812 Answers
SOURCE: i have installed mblaze on
Do you use any fire wall just disable or add in your fire wall mblez.
If you need more information, reply me soon.
Thanks
Posted on Feb 25, 2011
Error modem connecting device already connected not configured properly windows 7
Reconfigure device and you might want to try a hard reboot on the wireless
Oct 17, 2013 | Computers & Internet
Internet connection error 734 extra initialization command does not work.it leads to another error 692.
692 - Hardware failure in port or attached device.
This behavior can occur if any of the following conditions exists:
  • The modem is turned off or malfunctioning.
  • If you have an external modem, the serial cable is incorrectly wired.
  • If you have an external modem, the serial cable is not securely connected or has open connections.
  • The serial port or multiport adapter on the RAS server or client is malfunctioning.
  • The handshaking options for the modem are incorrectly configured.
  • The modem is unsupported, or the chosen emulation may be incorrect.
  • The modem .inf files become corrupted or the modem driver becomes corrupte
To solve this problem, use the appropriate method:
  • Reset your modem. Consult the documentation for information about how to reset the modem.
  • If you have an external modem, make sure that you are using the correct serial cable. For more information about requirements for proper cabling, refer to the "Cabling Requirements" section in Dial-Up Networking Help.
  • If you have an external modem, make sure that the serial cable is connected securely.
  • If you are using a pin adapter to connect your external modem to your serial port, make sure that the pin adapter is wired properly for modem communication. For example, a 9- to 25-pin adapter for a mouse does not work properly with an RAS serial setup.
  • Test the serial port or multiport adapter, and replace the adapter if necessary.
  • Make sure that the handshaking options for the modem are configured properly. Consult the documentation for information about the different handshaking options that are available for your modem.
  • Contact the modem manufacturer to see if any setup and initialization information is available for your modem. Also, check the latest Windows hardware compatibility list (HCL) to make sure that your modem is supported.
  • Use Device Manager to remove the modem. You can do this in safe mode or in normal mode. Restart the computer in normal mode. Windows will redetect the modem and reinstall the correct drivers.
May 12, 2011 | Computers & Internet
I have Cricket broadband and i get disconected very often and when i try to connect i get this error message: The Modem (or other connected device) is already in use or is not configured properly. The only...
Hi Ramon,
My name is Ryan and I work on behalf of Cricket. Please call Cricket Broadband Customer Service Center at 1-800-CRICKET and select Option 2.
*Before contacting a Customer Service Representative, please ensure you have the following information:
-Operating system (i.e., Windows X...P)
-Cricket Broadband Modem Device number (MDN) assigned to your wireless modem
Best,
Ryan on behalf of Cricket
Jan 30, 2011 | Computers & Internet
Error code 651
Error code 651
This error corresponds to an error in a modem or any other connecting device
Try the folloging the instructions below:
If this is a dial-up connection, and you are using a supported external modem, turn off and then restart the modem. Close and restart Network and Dial-up Connections, and then redial. If the problem persists, try connecting at a lower initial speed. See To change the maximum modem port speed. Make sure you correctly configured your modem for remote access. To check your configuration, see To configure a connection. If this is a virtual private network (VPN) connection, you might have specified an incorrect TCP/IP address in the connection configuration, or the server that you are trying to reach might not be available. To determine if the server is available, see your system administrator.
Oct 18, 2010 | Computers & Internet
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
Error 633
right click on my computer and go to properties then hardware in that click on device manger and choose the modem option just expand the list it will show the modem which you installed just right click on it and got to properties and choose the diagnostics option and there is one tab down query modem it will communicate with modem if you find the character or response that means modem is correctly installed or if it is not that means you need to re install modem driver.
Sep 17, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
Connecting to Internet using a dial-up modem
can you connect that modem first, to a phone line, and run a telnet or dial connection from control panel or accessory ?
Mar 20, 2008 | Computers & Internet
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Dell Vostro 1450 USB Docking Station Targus ACP51USZ $119 Logo
Alun Cox
