Question about Texas Instruments BA-II Plus Calculator
Calculate 2^1/5 using BA II plus - Texas Instruments BA-II Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press 2 y^x ( 1 / 5 ) =
y^x is just above the 9 key.
Posted on Jun 01, 2014
  • 3 Answers
SOURCE: No decimal display on TI BA-II calculator
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Posted on Jun 11, 2009
  • 8016 Answers
SOURCE: nPr and nCr key
On calculators you calculate permutations and combinations as follows
Enter the number n then press key nPr, and the number r
18(nPr)5=1028160
For combinations, use nCr key instead of nPr.
18(nCr)5=8568.
Hope it helps
Posted on Sep 06, 2009
  • 8016 Answers
SOURCE: Using e on the BA II plus financial calculator
To use the exponential function, you must enter the number then press [2nd][e to the x] or [e^x] for short.
e^(-0.1) is entered as (-)0.1 [2nd][e^x], where (-) is the change sign key
You will need to use extra parentheses to avoid errors.
20 - 18*( (-)0.1 [2nd][e^x] ) [=]
The Minus sign between 20 and 18 is the regular one. The (-) before the 0.1 is the change sign key (-) or sometimes labeled +/-. The asterisk is the multiplication sign.
Hope it helps.
Posted on Oct 15, 2009
  • 8016 Answers
SOURCE: is it possible to calculate cube root or higher
To extract the roots of orders higher than 2, you can use the universal power key labeled as [Y to x]. if the exponent is an integer 3, 4, 5, 6 etc.
it gives the cube the 4th power, 5th, 6th, etc.
If the exponent is 1/3, 1/4, 1/5, 1/6 you calculate the cubic root, the 4th root and so on.
When you use it to calculate the roots, the radicand (the number the root of which you are calculating) must be positive, otherwise you may get the result as a complex number.
The syntax of the command is value [Y to x] (1/ order of root)
Ex: cube root of 27 is entered as 27 [Y to x] (1/3)
Posted on Feb 21, 2010
  • 8016 Answers
SOURCE: Hi, are there MC, MR, M-, M+ functions in Texas
The calculator has 10 memories (0 to 9)
To store a number (13) in memory 6 type 13 [STO] 6
To erase the content of memory 6 (M6) store 0 in int: 0 [STO] 6
To recall the content of memory location M7 press [RCL]7
To operate on the content of memory location M5 the syntax is [STO] [Op] 5, where [Op] is the operation symbol [+], [-],[x], [/] [y^x]
Ex: to raise the content of memory location 4 to the power of the displayed value, you press [STO][Y^x] 4
To clear all 10 memory locations
press [2nd][MEM][2nd][CLR WORK]
In short, although you do not have the keys you are accustomed to, you have a lot more. And please do not blame me if you feel disappointed.
Posted on Apr 19, 2010
I need to calculate exponential to the power of a number with minos sign. I have a BA II Plus
Make sure you use the +/- key (located just right of the decimal point key) to enter a negative number. For example, to raise 3 to the -2 power, press 3 y^x 2 +/- =
Jan 13, 2013 | Texas Instruments BA II PLUS Financial...
How do I compute fractional exponents on the TI BA II Plus calculator?
The same way you raise a number to a non-fractional power, using the y^x button. For your example, press
3 y^x ( 1 / 1 2 ) =
or
3 y^x 1 2 1/x =
Dec 08, 2012 | Texas Instruments BA-II Plus Calculator
My BA II plus professional showing wrong answer while computing "N" during TVM calculation
Make sure you have P/Y set to 1 and BGN/END set to END. With those settings, pressing 9 I/Y 9 2 0 FV 1 0 0 +/- PMT CPT N should produce 7.00 .
Aug 25, 2012 | Texas Instruments BA-II Plus Pro...
How do I create a histogram on BA II Plus?
A histogram is a particular type of bar graph used to represent the distribution of a set of data. However, the BA II Plus is not a graphing calculator, so you will not be able to create a histogram on it.
Feb 28, 2012 | Texas Instruments BA-II Plus Calculator
I need to be able to quickly turn a decimal into a fraction using the BA II plus calculator from Texas Instruments
The BA-II Plus is designed for financial applications. It does not do fractions, as do some calculators intended for school use.
Sorry if that wasn't the answer you wanted to see, but there it is.
Sep 03, 2011 | Texas Instruments BA-II Plus Calculator
What do I press to get the exponent 3 on BA II PLUS? Thanks
To raise a value to a power, use the y^x key located just above the 9 key. For example, to raise 2 to the third power, press 2 y^x 3 =
Unlike most calculators, there is no dedicated key for decimal exponents. You will have to use the above procedure to raise 10 to an exponent.
Nov 09, 2010 | Texas Instruments BA-II Plus Calculator
BA-II Plus Calculator: hi. i have a texas instrument calc & its model...
There isn't one.
May 17, 2010 | Texas Instruments BA-II Plus Calculator
Jun 03, 2009 | Texas Instruments BA-II Plus Calculator
Interest only payments
I gave up using the Texas BA II. I used an on-line mortgage calculator for interest only. I was able to get a full printout.
I would like to learn more about the BA II and how to do this type of math on it.
Thank you
Mar 02, 2008 | Texas Instruments BA-II Plus Calculator
Texas Instruments BA-II Plus Calculator Logo
27 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
