Please set up dial mode
SOURCE: Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
SOURCE: fax machine borther fax 565
change the distinctive mode to off.......menu-miscell.-distinctive
Abdalla Alyhabib
[email protected]
SOURCE: SPEED DIAL
Press
Function
72
set
touch yellow keyboard key like 01
enter fax number
set
enter name
set
stop
SOURCE: we have a fax machine
You need to replace the backup battery located on the main printed circuit board. These are usually soldered onto the board but some have receptacles which make replacement easier.
