Question about Maytag 21.7 Cu. Ft. Top-Mount Refrigerator - White
Freezer is only at 22 degrees - Maytag 21.7 Cu. Ft. Top-Mount Refrigerator - White
Freezer temp does not go below 22 degrees, have been monitoring for over 24 hrs.
Potential fan or defrost issue. Icemaker runs on temperature.
Jun 19, 2014 | Sub-Zero 632 / S
Just had the thermistors replaced in the frigde freezer the fan is working now and the freezer is - 22 but the fridge is at 14 degrees.
Where are you getting these temps from? If your unit is in Celsius mode, that would mean fridge is 57.2 degrees and Freezer would be -7.6 degrees. Without a model number I am unable to see the style of controls you have. Double check all settings are in the middle, meaning if you have a digital display, temp @ 0-36, if you have dials make sure they are set to the middle ie..(a-e then set at c, 1-9 set at 5).
I hope this helps...
Jul 23, 2011 | Refrigerators
AFTER AN ELECTRIAL SURGE, THE CONTROL PANEL'S FREEZER TEMPERATURE DISPLAY ALTERNATES BETWEEN "0" AND "31". IS THERE A RESET BUTTON? OR HOW CAN I BE SURE THERE IS NO DAMAGE TO THE...
Hello
You can reset by unplugging fridge for 3 min then plug it back in.It may be looking for degrees in Celsius or degrees in Fahrenheit.
Have you set that yet.
Mar 28, 2011 | Maytag 22 cu. ft. Bottom Freezer...
Our 3-door traulsen freezer had new seals installed (incorrectly) which caused the freezer to stay on continously for 12 hrs. The compressor was frozen with ice and the temp increased to 22 degrees. I...
when you say the temp was increased to 22degrees you do mean
-22C not +22.if it was minus 22C then just ensure seals are on correctly and leave it switched on it will settle down to -18C in its own time....do not use any heating on the compressor,just leave it.
Aug 20, 2010 | Refrigerators
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
Feb 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Jun 10, 2009 | GE Profile Stainless Bottom-Freezer...
Kenmore 14.8 cft - temperature between 5 and -22 degrees (-15 and -30 C)
Big...this is likely normal. I'm not sure where you're measuring that temp from. If it is the fan outlet, this is possible. The fact that the unit is staying below 5 degrees means that it is within spec. You do have a warranty. Ask Sears to come on in and check it out.
Your 'duty cycle'...that amount of time that the compressor is on should be about 20% of a unit of time...say 25 minutes out of 2 hours. Is that about right? If so, enjoy your ice cream.
Dec 01, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Open Questions:
See all Maytag 21.7 Cu. Ft. Top-Mount Refrigerator - White Questions
Maytag 21.7 Cu. Ft. Top-Mount Refrigerator - White Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
