Question about Ricoh Caplio R7 Digital Camera
Dear Fatalbert ....i tried all settings all r same ! what other settings do u recommend ? hope you must have seen this camera yourself also. pl advise what more should i try to do with the settings other than auto - mode . pl find attached one pic in the auto-mode too ! Regards, Ajay
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
In most P&S, the program mode is the best to play with, you'll find lots of settings to play with, do an online crash course on which means what, and go ahead and shoot. :)
Posted on Oct 18, 2013
My nokia 5300 camera is not working.As soon as i open a camera mode it says camera on standby and operation failed
Switch off the phone, remove the memory card and boot again without the memory card. Now try accessing the camera, hope it's working now. I would suggest you to scan the memory card or format it (i recommend formatting the memory card so that it'll not fail).
If the problem persists even without the memory card, reset your phone's settings to Factory Default by going to the Settings > Restore Factory (open the settings, press up key once, you'll see the "Restore Factory") using the code 12345. Your phone will automatically restart. Now try again with camera.
If both the above methods don't help out, your only option is to flash the phone or update the firmware. But I don't recommend do these yourself, a small mistake or incomplete will damage the phone or will create more problems. You can visit any service center or any mobile repairing center and get it done with a small fee.
Good luck.
Thanks for using FixYa.
Aug 10, 2010 | Nokia Cell Phones
Auto focus problem
Well, if all the software is ok, maybe the button is damaged and not able to give the two modes any more. If the camera has done it´s fair share of pictures, maybe it needs some repairs... since you´re the first that I personaly have heard is in this situation.
Mechanical things get broken more easily than we want, I guess. I´d recommend a repair shop for your camera and let us know how you ended up, please.
Oct 12, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
All pictures with flash come out underexposed and can hardly be seen.
Hi!
It sounds like the flash unit has to be replaced - I have seen problems like these with these cameras and changing the flash unit helped. I'm afraid you won't be able to repair it yourself. You should contact your local Canon service center.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot A85 Digital Camera
Canon XTI Flash problems
I personally would recommend getting expert help - flashes produce a high voltage flash (several hundred volts to several thousand), and can be dangerous - even this camera's flash gun. It sounds like it is shorting when you tap it, so likely a loose connection. You can't do it yourself, so get proper advice. You can try your local camera dealer, or better, send it back to Canon Service. If out of guarantee, get a quote for looking at it. They will likely have come accross this before, so don't worry - it is likely fixable .
Hope this helps
Nov 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Virus
Try to map the IP of the computer you are trying to access
Click run>type \\IP of the computer the click ok. If this will not work, try to ping the IP of the computer see if the computer is accessible tru ping.
Sep 11, 2008 | Microsoft Windows XP Professional With...
Black screen on my Canon PowerShot A640
I had this problem too. Try the "DISP" button (bottom left on the display side of the camera. It allows you several viewing options, and is easy to accidentally hit and turn the LCD screen "off."
Apr 27, 2008 | Canon PowerShot A640 Digital Camera
Memory Card Error
Two suggestions:
1. Try gently blowing clean air into the memory card slot. It's possible a bit of lint or dirt is on the contacts and needs to be removed. A can of compressed air will work for this.
2. (More advanced) If possible use a q-tip to gently rub the contacts for the memory card inside the camera. Again, you're trying to clean the contacts.
If neither works you'll have to consider bringing or sending your camera in for service. It's possible that it needs to be opened up for service and I don't recommend that you do that yourself.
Dec 19, 2007 | Canon PowerShot A630 Digital Camera
Blurry pics
Sounds like the auto focus mechanism in the camera needs to be cleaned and adjusted. The camera can be repaired yourself but it takes a great deal of mechanical know how and knowledge. Several links have already been posted on this issue.
I recommend you take the camera to a repair shop and have it done correctly.
Dec 10, 2007 | Samsung Digimax S630 Digital Camera
Ricoh Caplio R7 Digital Camera Logo
29 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
