Question about Kyocera Mita Office Equipment & Supplies
Duplo 203 drum does not stop turning when i press the drum rotation switch
4 Suggested Answers
  • 212 Answers
SOURCE: whirlpool Dryer Drum Won't Rotate
sounds like your drum belt has broke. remove two phillips screws at lint screen. pull top towards you then up. you will expose drum.
Posted on Jun 24, 2009
  • 212 Answers
SOURCE: dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
barkencoa
  • 3463 Answers
SOURCE: Hoover AM120 - Have replaced motor brushes - drum
I would recommend that you consider replacing the washer, as it certainly sounds like a faulty programme control, and they are expensive
The motor itself must be o/k, otherwise it would not function at all
Posted on Nov 28, 2010
Asko T701 stopped running.
Test the wirings to control panel and the switch.
Try also a different outlet, and eventually check with a tester the power cord.
Also the switch must be tested.
If the wirings are ok then the whole control panel can be replaced.
If you want to buy parts you find them here.
Sep 13, 2008 | Asko T701 Electric Dryer
Duplo dp-205A scanner open problem
duplo dp-203 problem scanner open
Feb 25, 2013 | Office Equipment & Supplies
Kenmore model # 86470810 buzzes when I press start but won't run
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch
Sep 21, 2011 | Kenmore Dryers
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Mar 19, 2009 | Duplo DP21L Copier
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Jun 15, 2008 | Magic Chef Dryers
21 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
