SOURCE: I JUST WANT TO FIND THE DAM MANUAL FOR MY HEIL
[PDF]
2100-016 (1976 11)File Format: PDF/Adobe Acrobat - View as HTML
Operate the manual reset button on top of control. ..... 19 Fuel Unit - Sundstrand A1VA-7012. 20 Fuel Unit Mounting Screw. 21 Oil Line Fitting ...
www.bardhvac.com/digcat/volume_3_cd/install.../2100-016.pdf
[PDF]
SOURCE: furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
SOURCE: heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
