Question about Bosch Dishwashers
Sd6P6B bosch dishwasher showing e 15 - Bosch Dishwashers
2 Suggested Answers
  • 51 Answers
SOURCE: Bosch dishwasher showing e:15 error code.....how do you fix it?
E15 means that unit doesn't think it's getting water
If there is not water inside the tub then you have a problem with your electronic water valve and will need to have it replaced. If you do have water inside but it's still giving you the error, then you have a bad flow meter that iwll need to be replaced
Posted on Nov 18, 2012
I have a bosch dishwasher that shows an arrow displayed on the floor. What does this mean? MODEL SHP7PT55UC/07
That is a time light. It is a Bosch feature that shows what the machine is doing.
Jun 19, 2016 | Bosch Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
Its out of work and shows E:15
This error message is normally an indication that there has been an overspill of water in to the base and triggered the antiflood mechanism.
Try tilting the dishwasher back to allow excess water to run out and then retry the wash cycle. If it still gives the E15 code then there is a leak on the system.
Jul 29, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher, dishwashing liquid caused bubbles everywhere
clear the error then run the unit several times without any soap at all -- this should clear up the problem.
Sep 02, 2009 | Bosch Dishwashers
Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
Aug 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dishwashers Logo
114 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
