Question about Microsoft Office Standard for PC
Connecting html form to Ms-access data base
I want to connect by feed back form to ms-access data base.In that form so many fields Im going to create & 2 button 1 for save the record and another for search ie;when im going to enter rollno it has to display the full detail in that form
  • 4 more comments
  • vibha Sep 26, 2007
    I hope I will get the solution for my problem.
    thanking you
  • Anonymous Feb 08, 2008
    I dont know how to use MS Access i want to save my data using Ms Access will you please help me thank you very much for your kindness
  • Anonymous Mar 10, 2008
    have aform with five fields name age gender location email address iwant to create two button one for save and the other for search when click on save the content of the form is submitted to ms access database when iclick on search it search for given record and display it on the webpage
  • vijisparthi Apr 27, 2008
    I want to connect by feed back form to ms-access data base.In that form so many fields Im going to create & 2 button 1 for save the record and another for search ie;when im going to enter rollno it has to display the full detail in that form and give me a example code please ........
    Comment by Parthi,
    thanking you!!!
  • Anonymous Oct 20, 2008
    Hello
  • Anonymous Mar 09, 2009
    i want to record all the data in my HTML form to MS Access, its beacause it is easier to use than MySQL...wondering if that could be possible...
    Novelist:
    Scholar:
  • 117 Answers
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Posted on Sep 29, 2007
I have already stored in my ms-access database so how can i call the values on the html webpage as soon as the specific value is selected on my html webpage
Posted on Oct 15, 2008
Just mail me how can I connect my html form with Access
Posted on Mar 27, 2008
SOURCE:
Can u plz mail me tha easiest way to use Ms Access, like Creating relationship, with the table, creating form, query etc.
In general you initiate this process by pressing the "Relationships" button on the MS Access toolbar. It is the button with three small boxes arranged in a triangle shape.
When it first comes up it will give you the option to add tables. You can add any set of tables including the possibility of adding one table more than once (you would do this if you wanted to create a relationship between fields in the same table).
Once you see the tables you're interested in, you simply drag the field from one table over a field in another table. The fields should be those that will define the relationship. Once done, you should see an Edit Relationships window. You can get back to the Edit Relationships window later by double clicking the line in the relationships window.
MS Access does a good job of figuring out the relationship type. For example, if you match a field in one table, that is not a key, with a primary key in another table, Access will make this a Many-to-One relationship.
This can become a very deep subject. Hope this at least gets you in the right direction.
Dec 18, 2010 | Microsoft Computers & Internet
I want to learn that how can i connect my HTML page with my DATABASE created in MS ACCESS so that i can fill my table in HTML page directly-
1. You can use Pages option in MS Access. The page in MS Access is the web page in MS Access which allows you to access database in MS Access database.
2. You can use MS Office Front Page application and use the Form builder and connect your database in that.
3. You can also use Google Apps Business Solution for this however the database will not remain in MS Access but will remain in Docs online.
4. You can use .net application developer for this as well but needs expertise in that.
Mar 09, 2010 | Microsoft Office Standard for PC
Im using html to create forms and want to store that data in ms access or any other backend so that more of the data is stored so i just want the syntax to be written in html that can connect the database
Dear friend, for this subjject you should use CGI scripts, you can't save them only by simple HTML codes, so I provide some useful links to learn how to save entered characters in feedback forms by these CGI scripts and HTML, I hope they could help you, just read these articles carefully.
http://www.yourhtmlsource.com/cgi/processingforms.html
http://www.rebol.com/docs/cgi2.html
http://www.help4web.net/webmaster/html_tutorial/chapter15.html
http://webdesign.about.com/od/forms/a/aabg073099a.htm
You can also make feedbacks form simply by FRONTPAGE, you just need to this software, select a feedback form template, customize it and setting up the form option about how to save, and where to save, but remember that if you use frontpage for this job, your domain should support frontpage extension too.
Good luck
Apr 15, 2009 | Microsoft Office Standard for PC
Hi all i want to launch a form when i click the data base file in MS access 2003 (the form is created inside the mdb file of access)
hi,
on MS Access 2003:
goto Tools Menu --> Startup --> select your form for "display form/page" dropdown
uncheck the "display database window checkbox and display status bar checkbox
Hope this helps.
Thanks.
Apr 01, 2009 | Microsoft Access 2003 for PC
How should i connect html page to MS Access
You have to create adodb.connection to connect the ms acesss database to web page
Jan 20, 2009 | Microsoft Office Standard for PC
Connectivity between HTML page and Ms-Access
<HTML>
<BODY>
Set MyConn = Server.CreateObject("ADODB.Connection")
MdbFilePath = Server.MapPath("sample.mdb")
MyConn.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
SQL_query = "SELECT * FROM Friends"
Set RS = MyConn.Execute(SQL_query)
WHILE NOT RS.EOF
<LI><%=RS("Name")%>: <A HREF="<%=RS("Link")%>">Homepage</A>
RS.MoveNext
WEND
</BODY>
</HTML>
Nov 11, 2008 | Microsoft Office Standard for PC
How to use passwd character in a table in ms-access 2003
When you create table where you want to store passwords, go to Edit Table, then select a field where the password will be stored, go to Input Mask field in Properties and type Password in that field. That will set up the field needed for storing passwords.
Aug 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Ms access
before this u should know what is databse.
ms access has various objects likw table,form,query,report etc..
table is a object which stores the actual data and form is used to enter the data in to the table and display the data from the table, while report is object which is used to desplay your data in required formate.Query is used to fetch the data from the table in customised formate.for that u should have knowledge of SQL.
Nov 14, 2007 | Computers & Internet
Microsoft Office Standard for PC Logo
2,076 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
