Dimplex duo storage heater making clicking noise and also the programmer dimplex PX4 is no longer working
rizla
  • 1463 Answers
SOURCE: dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Posted on Feb 05, 2009
SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Posted on Feb 13, 2009
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
SOURCE: motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Posted on May 19, 2009
SOURCE: I have two dimplex XLN storage heater, it was
It sounds as though it has tripped the internal cut-out - this can be manually reset quite easily by yourself. It would probably be best to ring Dimplex customer services on 0845 6005111 to get them to talk you through it step-by-step though.
Posted on Dec 21, 2009
Do Dimplex XT C Storage Heaters contain Asbestos?
Probably a little bit late to be answering this now, but no they do not contain asbestos.
You could have received an answer to this within about 5 minutes by calling Glen Dimplex direct or even any electrical wholesaler
Mar 06, 2015 | Dimplex Heating & Cooling
I have economy 7 dimplex storage heaters and last winter they just decided to stay stone cold and not come on one day. can these be repaired or do i need to replace the whole heater? thanks
I belive inside the front cover this a bimetal reset in one of the corners top right I think you have to push this back on it makes aloud click . do this with the power off , have done this but a long time ago . hope this helps
Sep 22, 2011 | Dimplex Heating & Cooling
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
My dimplex xms718n storage heaters are not heating up properly - the bottom half is still cold in the mornings what could be causing this?
I have recently had xms718n storage heaters installed and about once a week none of them seem to come on at all. Do you know why?
Dec 09, 2010 | Dimplex Heating & Cooling
Dimplex OFC2009TI programmer not working
yeah i now have this problem did you find a solution?
Jan 26, 2010 | Heating & Cooling
I have two dimplex XLN storage heater, it was working last year but after someone put damp clothes on it, they are not working, could you help me please
Dec 18, 2009 | Dimplex DS5603 Heater
Dimplex storage heaters dead
sir please check the heater connection inside.then check if there are any damages in the control cables.
Mar 07, 2009 | Dimplex DS5598 Mid-Size Heater
My dimplex night storage heater has stopped working.
Feb 01, 2009 | Dimplex Heating & Cooling
Dimplex FXL24n wont heat up over night
the clip should click and the heater reset its self have you repalaced the clip ? some times you have to press the clip hard to get it to click
Nov 26, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
211 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
