Question about Epson Aculaser Cx17nf
The display is saying check CTD unit. Clean CTD sensor. I have cleaned the glass but this message is appears
Message ctd sensor dirty clean 092-310
Anonymous,
You can click the link below and download the online User Guide. The User Guide will provide information on cleaning your CTD Sensor.
Dell 1350cnw Printer
http://dell.to/1EZ8hL2
Thank You
Dell-Jesse L
Dell Social Media and Communities
Mar 16, 2015 | Dell 1350cnw Laser Printer
How do you turn off the message "clean glass" in the display panel on a IR-2525
The glass is still being "PERCIEVED" by the units sensors as dirty.It may have an anomaly unperceived by the human eye. Use Debruce Polish and rest assured you now have a clean surface. DeBruce Polish is "NoN-Abrasive", "NoN-Toxic" AND odorless. Perfect for Stainless Steel and ALL Glass. Find @ DeBruce Polish Non Toxic All Metal Multi Surface Cleaner debrucepolish...
Feb 26, 2014 | Office Equipment & Supplies
CT sensor error Error code 092-310 error code 00002000 restart printer. please note will not restart also unpluged still no respond
The CTD Unit is a Sensor on or near the Transfer Belt Unit on your Dell Laser Printer. This error is advising that the sensor is dirty and may need cleaned.
If you receive one of these errors please clean the CTD Sensor on the Printer.
  1. CBR Tech Solutions orhttp://www.cbrtechsolutions.com
Apr 10, 2011 | Office Equipment & Supplies
Colored lines on a copy page
To fix the colored lines on a copy page do the below steps
  1. Disconnect the power cord, wait five seconds, and then plug it back in. This will reinitialize the unit and force the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the unit must be serviced.
  4. Verify that the alignment page is placed on the scanner glass or in the automatic document feeder (if equipped) correctly. Place the printed side down.
  5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
Dec 10, 2010 | HP OfficeJet k60 All-In-One InkJet Printer
I have an orange error light.
If it's not blinking it one of: The PHD (Print Head Device), or belt unit, life is coming to an end. Clean the CTD sensor. Try to clean the CTD sensor with a dry cotton swab. The sensor is located on the front cover (inside).
Mar 23, 2010 | Dell 1320c Laser Printer
Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Jan 19, 2010 | Dell Office Equipment & Supplies
What is the ctd sensor? it says it needs to be cleaned
Hi!
The CTD is the Automatic Density Sensor. Below is a step by step on how to perform nearly all maintenance procedures for the 5100 series (Including how to clean the CTD sensor)
Should be just what you're looking for.
Hope this helps!
Dec 06, 2009 | Dell 5110cn Laser Printer
There is a "CTD Calibration Error" at display! where is the "ctd"?
CTD detects the amount of toner on the drum and is used by the printer to determine charge levels required for good image production. It is a part of the transfer belt unit and cannot be replaced on it's own. First try removing and refitting the transfer belt, making sure the electrical contacts are clean and undamaged. If that doesn't work, fit another transfer belt.
Apr 18, 2009 | Samsung CLP-500 Laser Printer
Epson Aculaser Cx17nf Logo
423 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
