Question about HP Computers & Internet
Hello, I have HP MS-7613 ver1.1. It was working just perfect until yesterday - when I replaced the power supply(for test purpose). It stopped working with that power supply, then I turn it on with his (working) power supply but again the motherboard didn't response at all, I am pretty sure that the problem accrued because of foult power supply(it was refurbished one) I think the power supply send to much electricity to motherboard and then it failed to start... I tried too reset the CMOS settings, also tried to unplug all the cables(including ram,HDD etc) and left the comp for 1 day, but without success ( Would appreciate any advice. Thanks in advance.
  • Tigran Sargsyan Oct 17, 2013
    Details about computer: HP Pro 3130 MT
  • 30 Answers
You may have fried the MB...there isn't a power surge protector for Mobos
Posted on Oct 17, 2013
Testimonial: "Yes maybe, I am going to send it for some technicians.. By the way I'd like to add that I've also used the same power supply(refurbished) on Intel's motherboard(D101GGC), on that MB it works for some time(for 2 or less minutes) then abruptly switches off. I guess Intel's MB's has some protectors for this kind of cases..."
LadyTech99
  • 141 Answers
SOURCE: Emachine flashing yellow lights, fans power up when P8 is unplugged
Did some research and found this site which will tell you which pins to test. It is possible also that its not powerful enough for the devices you have. I would try again only giving power to the motherboard pins, of coarse and the hard drive. If works then plug one device at a time.
Good luck
http://articles.techrepublic.com.com/5100-10878_11-1046822.html
Posted on Jul 05, 2008
compdoctor20
  • 172 Answers
SOURCE: Dimension 2400 Flashing Power Light
This is a blown motherboard, i have just repaired one of these today using a new board.The processor socket has blown. Boards currently available.
compdoctor2005@btinternet.com
Posted on Nov 27, 2008
  • 233 Answers
SOURCE: Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Posted on Jan 07, 2009
  • 166 Answers
SOURCE: Gateway 831gm not booting. Fans come on but no boot process.
2 questions:
When you say new motherboard do you mean an actual new motherboard or new to that machine, but came from another used model?
When you say you tested the power supply do you mean with a voltmeter/ammeter or put it in another computer and it worked?
I worked on several gateways with similar problems and it boiled down to motherboard issues.
I tested it by replacing the power supply with a bigger (used) power supply and it worked great (for 1 time) and then put the other power supply back in to confirm my diagnosis and yep it wouldn't boot. The next morning I was going to run some virus/malware cleanup and installed the other (known good) power supply and it would not work. I tried all day to get it to boot and it did about twice in a 4 hour period. When it did run it would run great but any attempt to restart it would cause it to crash. No ryhme or reason, it would not fail the same way more than twice. Sometimes beeps, other times no beeps, sometimes it would start up with no video (could hear the Windows starting sounds) other times it would start up normal. I could let it sit and it would start or I could keep trying in sucession and it would eventually start. Some times the fans would slow down from a roar, sometimes they wouldn't. So with a known good power supply that had 150 more watts than the original I diagnosed it as a failed motherboard. But if you have put in a brand new motherboard then I would replace the power supply, because a bad power supply does not mean no power, just not enough power. Please post back and let us know what you find out.
Posted on Mar 31, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 530 won't start up - is motherboard dead?
From your description, I agree with you assessment of a likely Motherboard failure.
Posted on Mar 09, 2010
Replace battery MS-7613
The battery is round and shiny. Pick up one edge of the battery and slide it out if it's socket. Obtain a replacement with the same numbers or equivalent 3 volt coin cell and slide it back into it's socket. When you reboot, immediately enter BIOS setup and set the correct time and date. Then continue to boot.
Apr 09, 2014 | MSI Hp Iona-gl8e Oem Motherboard Ms-7613...
New memory stick 4 gb doesn't work
you cant do that. memory is always in PAIRS. The sockets are Colour Coded for each PAIR. two blue two black. the largest may need to be 1st Pair. suggestion: take all 4 out. put 2 largest back in as 1st pair see if pc is ok. then add 2nd pair. see if ok. https://support.hp.com/gb-en/document/c02014355 https://support.hp.com/lamerica_nsc_carib-en/product/HP-Pavilion-p6000-Desktop-PC-series/4079858/model/4123110/document/c01989040 https://www.mrmemory.co.uk/memory-ram-upgrades/hp/pavilion-desktop/p6324uk?search=hp+p6324uk
Dec 20, 2017 | MSI Hp Iona-gl8e Oem Motherboard Ms-7613...
No Power. Blown fuse or dead power supply?
Replace the power supply. Definately not the fuser
Jul 23, 2017 | HP LaserJet 1200 Printer
HP motherboard ms-7613 failed...how can i get a replacement?
Should be able to find o a great used one on line
Aug 03, 2013 | HP Computers & Internet
Need large, clear diagram for MSI motherboard, type ms 7613-iona gl8e
Hello this mainboard belongs to the HP/ COMPAQ support:
https://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655
The manual:
https://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655&
You can`t find anything at the msi support site.
Do you get any picture (blue screen of death) ???
Any beep sound ???
This fault could be: ram failure,harddrive,graphic card,cpu.
Or sinply mainboard is dead.
It`s always difficult to do fault finding on a mainboard.
Many thing can go wrong.
And it will sometimes cost more
than a new mainboard or pc to solve the problem.
Ask a qualified repair shop (hp support) about known issues
with this mainboard.
Good luck
Nov 25, 2012 | MSI Computers & Internet
HP mediasmart EX470
Hello it depends on your current operating system.This could have happend after the update from MS yesterday.
It looks like a failed update.
Here is a link if you are running server 2008:
http://serverfault.com/questions/362759/server-2008-stuck-in-reboot-loop-configuring-updates-stage-3-of-3
Good luck
Nov 13, 2012 | HP MediaSmart Server EX470 (GG795AA)
I want details for my motherboard ms-7613 ver 1.1
You can get the specifications of this motherboard from this WEB site.
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c02014355&lc=en&dlc=en&cc=us&product=4262655
Apr 28, 2011 | MSI Computers & Internet
LCD monitor stopped working on my CPU but works on my Brother's
Definitely some electrolytic capacitors are blown inside the monitor in power supply module. Open it and observe any of them rounded on top, replace with proper ones.
You see, controller operations with VGA and DVI inputs takes different current from the supply, that's why it may take different time until PWM chip in the power supply will decide it is time to shut down before getting smoked.
Replace capacitors.
Sep 06, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Computers & Internet Logo
198 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
