Question about Home
Where can i get kitchen shears that come apart so that i can clean them easily?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 97 Answers
You can probably find come-apart shears in cookstores and kitchenstores because most professional kitchen shears come apart for better cleaning.
If you want to get them online, tho, I found these on amazon:
http://www.amazon.com/Wusthof-5558-1-Come-Apart-Kitchen-Shears/dp/B0000631ZM
Posted on Oct 17, 2013
How do I sharpen my pruning shears?
You can use a mill file to sharpen your shears fairly easily. See this instructable page. Sharpen Hedge Shears with File
Jan 28, 2014 | Garden
What can i do with kitchen shears?
Kitchen shears are a very useful item to have in a kitchen. They can easily and comfortably substitute a knife in many tasks. For example:
- Cutting fresh herbs and spices
- Cutting the roots off vegetables before using them
- Cutting all kinds of raw pastries (like phyllo) and doughs (pizza, pasta etc)
- Snipping pieces of cheese
- Cutting poultry, meet and fish both raw and cooked (for example cutting off wings, cutting poultry into smaller pieces, cutting scales and finns off fish, cutting rotisserie chicken, cutting open crab legs, trimming fat off meat etc)
- Cutting fruits and dried fruit
Shears are also very useful in a kitchen as normal scissors, to cut string, wrapping paper etc
Oct 17, 2013 | Home
Which is the best kind of kitchen shears?
This article (http://www.cooksillustrated.com/equipment/overview.asp?docid=27679) considered different kinds of kitchen shears of different prices and found that the best shears would be longer but balanced. That would come apart for cleaning, but only after they'd been opened 120 degrees. With a good grip on slippery food. Strong blades but not too hard to close.
My personal suggestion is the KitchenAid shears, that you can find here:
http://www.amazon.com/Kitchenaid-Classic-Shears-With-Black/dp/B0050U240O/ref=sr_1_1?s=home-garden&ie=UTF8&qid=1381749011&sr=1-1&keywords=shears
or the Ergo Chef shears:
http://www.amazon.com/Ergo-Chef-Function-Come-Apart-Scissors/dp/B009PBSDNG/ref=sr_1_9?s=home-garden&ie=UTF8&qid=1381749011&sr=1-9&keywords=shears
Oct 17, 2013 | Home
Engine turns over but wont start
It sounds as though you may have a sheared flywheel key. The keys are made of aluminum and shear easily if the flywheel is not tight. Remove top cover and flywheel retaining bolt/nut. Examine key for location with slot in crankshaft. If sheared, orient the flywheel slot and crankshaft slot so that a new key fits. Be sure flywheel and crankshaft mounting surfaces are clean and free of oil/grease. Tighten crankshaft retaining bolt/nut to 90 ft lbs. Flywheel posisition is maintained by friction between it and crankshaft.
May 06, 2013 | Briggs & Stratton Garden
Can I put my kitchen shears in the dishwasher?
Blades shouldn't be put in the dishwasher. It will ruin the blade and also the handle. Wash the shears with hot water and soup.
Jan 14, 2013 | Home
Can I use kitchen shears to cut raw chicken?
Sure, that is one of their main purposes. They can also cut parchment paper, fresh spices, twine, and pie crust.
Jan 14, 2013 | Home
Spills have run down inside the oven door and stained the glass of the window (on the inside). Can I easily take the door apart to clean it? There are two screws on the inside of the door...can I unscrew...
experimenting is always easy if dont care about the repercussion ,it will be easy to remove it but not easy to assemble it back you can clean it by keep it open and you should use some catalytic solution for it
Feb 25, 2010 | Kitchen Ranges
Plasric dish has fused to the element
Use strong kitchen shears to cut away as much of the bulk as you can. Without gouging the round element, scrape it with the kitchen shear blade and run a short cycle. When the drying cycle has run for several minutes (you will smell that the element is heating)
open the DW and again use the shears blade edge to scrape the residual plastic from the element. You may need to repeat to get it all removed.
After you have cleaned it up, do some checking during some loads to make sure the heating element is not being turned on continuously during all cycles. You have not provided the the make/model number, so it is hard to get more specific.
May 09, 2009 | Dishwashers
Have Maytag Model #MER5765Q - Door handle came off (slight weight on it caused it snap off). No broken/sheared bolts or broken plastic. Can't figure out how to reinstall. Help!
u have to take whole door apart to get to it . remove the door then take screws out from bottom and sides then u can removbe the glass to see the other screws helping to hold handle on
Mar 17, 2009 | Maytag MER5765Q CleanDesign Electric...
Oven windows
I have the same problem. Two years ago the service representative came to my house to replace the door seal in my upper oven. He had to take the door apart to remove and replace the part. I used that opportunity to clean the interior glass partitions. I watch how he took it apart and put it back together again. I would not recommend trying it yourself. Also, local service reps. would clean it for you for a nominal fee. The problem is taking the bigger heavier door in which I have to do with mine.
Jun 18, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Home Logo
731 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
