Question about Epson Office Equipment & Supplies
EPSON M1200 error E304
I cannot print in the epson m1200 printer. It receives an error message of E304. both lights(blue and red) keep on blinking. what to do? thanks
  • jayandra
    jayandra Jan 07, 2014
  • 300 Answers
SOURCE: Epson CX11NF Error Message Service Req E511
This is from the service manual
Service Req E511
�� Possible parts that caused the error�� Troubleshooting
�� Photoconductor Unit �� SENSOR TR-0
�� HARNESS-ASSY XERO �� MOTOR ASSY P/R
�� HARNESS ASSY MAIN �� PWBA MCU�� LV/HVPSStep Check Yes No
1 Check of Photoconductor Unit attachment
Re-attach Photoconductor Unit.
Does the error recur when the power is turned
ON?
Go to Step [2]. End of
procedure
2 Operation check of Photoconductor Unit
Is the Drum of Photoconductor Unit rotating?
Go to Step [3]. Go to Step [10].
3 Check for dirt on silver seal on Belt in
Photoconductor Unit
Remove Photoconductor Unit.
Turn gear of Photoconductor Unit until silver
seal attached to Belt can be seen.
Is silver seal dirty?
Replace
Photoconductor
Unit.
Go to Step [4].
4 Check of SENSOR TR-0 (TR0 Sensor)
Is SENSOR TR-0 attached securely?
Go to Step [5]. Re-attach
the SENSOR
TR-0, and go to
step [5].
5 Check of dirt and foreign bodies on surface
of SENSOR TR-0
Are there any dirt or foreign bodies on the
SENSOR TR-0 surface?
Clean to remove
any dirt or
foreign bodies,
and go to step
[6].
Go to Step [7].
6 Does the error recur when the power is
turned ON?
Go to Step [7]. End of
procedure
7 Operation check of SENSOR TR-0
The voltage of P416-2 ↔ P416-3 on PWBA
MCU is 5 VDC when silver paper or other
reflective object comes close to the sensing
area of SENSOR TR-0, and is 0 VDC when
the object is released?
Replace PWBA
MCU. (p.404)
Go to Step [8].
8 Check of 5 VDC power supply to SENSOR
TR-0
The voltage of P416-1 ↔ P416-3 on PWBA
MCU is 5 VDC?
Go to Step [9]. Go to Step [14].
9 Continuity check of HARNESS-ASSY XERO
Disconnect the P/J416 from PWBA MCU.
Do all of the wiring below have normal
continuity?
J416-1 ↔ J108-3
J416-2 ↔ J108-2
J416-3 ↔ J108-1
Replace
SENSOR TR-0.
(p.361)
Replace
HARNESSASSY
XERO.
10 Check after replacement of MOTOR ASSY
P/R
Replace MOTOR ASSY P/R. (p.398)
ON?
Go to Step [11]. End of
procedure
11 24 VDC power supply check to MOTOR
ASSY P/R
Disconnect P/J201 from MOTOR ASSY P/R.
The voltage of J201-1 ↔ J201-2 is 24 VDC?
Go to Step [12]. Go to Step [13].
12 Continuity check of HARNESS ASSY MAIN
Disconnect the P/J403 from PWBA MCU.
Is the continuity normal between all terminals
of J403 ↔ J200?
Replace PWBA
MCU. (p.404)
Repair broken
or shorted part.
13 Continuity check of HARNESS ASSY MAIN
Disconnect P/J502 from LV/HVPS.
continuity?
J502-9 ↔ J201-1
J502-10 ↔ J201-2
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
14 5 VDC power supply check to PWBA MCU
The voltage of P410-3 ↔ P410-4 on PWBA
MCU is 5 VDC?
Replace PWBA
MCU. (p.404)
Go to Step [15].
15 Continuity check of HARNESS ASSY MAIN
Disconnect P/J410 from PWBA MCU and P/
J502 from LV/HVPS.
continuity?
J410-3 ↔ J502-3
J410-4 ↔ J502-4
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
Posted on May 22, 2008
gwbm
  • 353 Answers
SOURCE: Epson stylus c45 (Problem)
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them
for sale very cheaply on E-Bay.
Posted on Feb 10, 2009
websnail
  • 419 Answers
SOURCE: EPSON R1800 END OF SERVICE LIFE
You have a few choices on this one.
1. The SSC utility mentioned by Jacklee366 is usually the first port of call but it may not work in some situations. Worth trying regardless
2. Epson have an official reset utility which is available to North American printer owners who have a valid serial number (back of your printer).
You just fill out this form and you will then get access to the utility (the one eagleflh/bos_dsl is reselling with his kits)
3. You can also get access to the official service utility that service engineers use on these printers... A copy is available here.
IMPORTANT: This utility is a lot more powerful than the other two and requires a bit more hoop jumping but it can resolve the maintenance request very efficiently. Whatever you do, read the readme files and take your time if you opt to use it.
Hope that helps.
Posted on Feb 22, 2009
  • 700 Answers
SOURCE: green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
Posted on May 25, 2009
aicaxz
  • 511 Answers
SOURCE: 2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
Reset waste ink counter. Find at indoreset.blogspot.com
Posted on Jun 03, 2009
I saw a problem that "consumables Near end of service life"..now ,what can i do?
Not much. Most peripherals have end of life. That just means the manufacturer will no longer support. All you can do is buy a new one if need be. gl
Feb 05, 2013 | Epson AcuLaser M1200 A4 Mono Laser Printer
General error in epson stylus t13
HOW TO FIX MY PRINTER, IT DISPLAY A GENERAL ERROR, AND BOTH RED AND GREEN LIGHT IS BLINKING.PLS HELP ME..TNX
Jan 12, 2011 | Epson Office Equipment & Supplies
My Epson Stylus R230 has both red lights blinking alternately
Your printer has reach its maximum count of cleaning and printing. This need to be reset using epson adjustment program. But before resetting make sure that you have replace the waste pad inside your printer or it is much better to point outside the hose where the waste ink goes out.
Jan 21, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
Apr 18, 2009 | Epson Office Equipment & Supplies
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
690 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
