Question about Miele Washing Machines
Miele wt2780 washer dryer, displaying 'Technical fault 4 call service'.Can anyone tell me what fault 4 is?
3 Suggested Answers
  • 1122 Answers
SOURCE: Separate miele washing machine and dryer
if you go to sears .com click on parts put your model number in(should be inside dryer door)it willl break down and show you everything you need to know,let me know how it turns out,mike
Posted on Sep 28, 2008
SOURCE: miele washer dryer technical fault
techinscher fehler
wenn neustart ohne erblong
ruben sie den kudendienst
Posted on Oct 24, 2008
How do I fix a Miele W 2653 Wasker.
Hi dear. You did not mention what fault code but regards rest of your information, I would say 3 factors play up with it.
1- Tacho generator or it's plug faulty on motor
2- Motor Carbon brushes worn out or
3- Power/control unit ELP151-KD faulty.
I can advised to contact your local Miele center to diagnose your machine.Thanks.
Mar 17, 2016 | Miele Washing Machines
What is fault 55
Water Temperature. 55 is the temp of the water. There is no fault code 55. By displaying this temperature, it's telling you that the washer needs warm or hot water. You could have a faulty water valve. See if it fills on hot. If it is slow fill on hot, it would also display 55.
Aug 02, 2014 | Miele Washing Machines
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Flashing F40
I'm sorry to say that this is a controller problem.
The program is interrupted and the drain pump is operated. The display shows. If you have a full alphanumeric display it will show Technical fault F40. Call the Service Department. The buzzer is activated for 2 minutes.
Cause:
The controller has a fault that cannot be repaired by the service department
Remedy:
Replace the controller.
Jul 26, 2011 | Miele Dishwashers
The buzzer sounds and the rinses indicator light flashes and the programme sequence display " - - - " appears in the display. This occurs at the end of all programmes just as it starts to spin.
Hi - I will tell you whats wrong with the machine, but you will need to get someone familiar with Miele equipment to fix it for you.
On this particular series - Rinse LED flashing means 3 - 4 things could be wrong with the washer.
Tacho - generator is faulty
Drive fault - electrical problem
Motor - has issues with starting
Blockage - drains - drive unit
Restrictions - of the drum turning.
Electronics - may be a component with an intermittent failure/decay.
It would be either one of the above or a combination of 1 or the other...
Jun 20, 2011 | Miele W435WPS Front Load Washer
I have a Miele T8013C that keeps beeping with a Fault on the container. I looked in the manual and saw nothing in the directions. Can anyone help me?
May 16, 2011 | Miele Dryers
Sep 28, 2008 | Miele XLWDSTAND Washer and Dryer Stand
Miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
Miele washer dryer technical fault 53
techinscher fehler
Mar 27, 2008 | Washing Machines
Washing Machines Logo
136 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
