Fixya forum problem with Marantz cd 7300-does not read disks. Replacement of laser pick up VAL 2212/08? But Nowhere to find it. Pls let me know the substitut for VAL 2212/08.. Many thanks in advance. Joseph Z.
  • 78 Answers
SOURCE: Avic X1r will not read navi disks
I have had quite a few problems with copied discs not reading and it is usually the disc's but however in your case if you know the discs work on another unit then perhaps a later version of the discs were tested when the unit was repaired and therefore your earlier discs would not be recognised by the unit, and therefore your unit needs to be reset and i'm afraid this is not something you can do yourself, speak to northolt and see if this is the case.
Posted on Mar 17, 2008
SOURCE: Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Posted on Jul 10, 2008
konzzz
  • 255 Answers
SOURCE: DVD player trouble after new laser pick-up
ok, this is a compatibility issue.try looking at the lens but not directly if it lights on when loading a disk.if ok.make sure the ribbon wire is securely attached especially the the terminal are not folded.
Posted on May 28, 2009
  • 99 Answers
SOURCE: Laser is malfunctioning on my Marantz CD Recordable DR6000
the laser in your DR-6000 is exactly the same as what's in the philips cdr-775 and cd-r-770.
a brand new laser for these are very hard to get hold of and are very expensive. personally i would look out for the above philips models on ebay for less money then take the whole mechanism out and unscrew the servo board and then fit the marantz servo board in place of it and fit it back into your recorder.
i have done this on numerous occasions with no problems.
hope this helps.
Posted on Sep 12, 2010
  • 3 Answers
SOURCE: pls reg h-s philips cd 150problem
Hi, there,
I just have the same problem here in Taiwan. Now it's solved.
First, make sure phone line of your cordless phone is connected. Then, get to the advanced settings and key in default pin number (mine here is 0000), but don't press OK here. At the same time, push the "radial sign" in the center of CD 150 bracket for 3 seconds so it can deliver signals. Meanwhile, press OK button on the phone and if it's working, you will see
"waiting" and not long after that, no more PLS REG H/S.
Hope it's helping :)
also see :http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?mode=search&session=20110103075755_59.112.120.112&scy=TW&ctn=CD1501B%2F96&ds=CD1501B%2F96&slg=ENG&qslg=on&searchtext=registration&submit=Search
junana4van@gmail.com
Posted on Jan 03, 2011
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
Marantz CD-5000 CD player
If I may add to XX's post and with his indulgence...
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
Image was adapted from How CD Works.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 22, 2008 | Marantz CD-5000 CD Player
My marantz cd 7300 reads no disc probably needs a new laser, where do i get one, thoes sold on ebay look different, many thanks, Peter.
This sounds crazy but it works for some reasons. Marantz CDR500 would not read and initialise some blank discs but no problem with reading finalised ones and erratic would and would-not work. Tried cleaning lens and even blowing ar through it. Before I wasted money in air I thought why not try hairdryer into open tray and lens area and just for measure across blank CD. I know this sounds weird but it worked every time and machine will read any make of disc like this. I do not have any scientific explanation only the fact that it works!!!
Nov 23, 2013 | Marantz Audio Players & Recorders
'no disc' keeps appearing
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 09, 2010 | Philips HTS3544/37 Theater System
The SA-1 cannot read CD and Display is off
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Marantz SA-1 CD Player
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
Marantz CD63-SE fails to load/read/recognize disk - disk spins but "insert disk" is the only result
I think the laser needs re-aligning or the laser unit itself is faulty. If you can find a competant technician. Hope this helps.
Oct 02, 2008 | Marantz Audio Players & Recorders
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
Cd does not read every time
I love Marantz! They make quality products that last and sound excellent! Most likely it a dirty lens. When a lens gets dirty, it can't read the cd as accurate. Unplug it, remove the cover, locate the cd lens take a q-tip lightly dipped in rubbing alcohol and rub it lightly on the lens (don't drip it too wet). This should help. Sometimes they also have a weak laser which can cause the same problems, but try the cleaning first.
Apr 23, 2008 | Audio Players & Recorders
Need CD Laser replacement for AVIC-D1
you are right and i have one for you i will sell you the whole unit board and all for 30.00 if you like that price e mail me at bologna_s@hotmail .com also you must pay for shipping probably 5.60 thank you
Dec 26, 2007 | Emerson EWD2203 DVD Player/VCR
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
