Question about Mercedes-Benz Vehicle Parts & Accessories
Hi will a mercedes vito 16" 5 stud steel wheel fit a 2004 mercedes sprinter many thanks.
    Master:
  • 359 Answers
In order to figure out if a wheel will fit your car you will need to know the lug pattern spacing (i.e 5x112) and centerbore (i.e 66.5mm) (if your wheels are hub centric). Also, depending on how big your brake calipers are you will need to consider if the wheel is big enough in diameter to clear them. Secondly, the lug bolts themselves need to be purchased correctly (if they do not come with the wheel) you will need to make them the correct length and type (conical or sphere) for the wheel.
Posted on Oct 17, 2013
Wheel torque settings
Aluminum and mag wheels 90-100 Ft. Lbs.
Jul 31, 2014 | 2010 Mercedes-Benz Sprinter
Car wont shut off when key is removed suzuki forenza 2004
Hi
Mercedes NEC device can learn an extra key to ALL MB MOTOROLLA AND HAVANA AMAZONAS PALERMO... EIS with black or chrome key Version57
Device can repair any CORRUPTED key data VIA INFRA RED
Device can repair the old 204 steering lock or program a new steering even if the old ESL in not exist
Device works by infra red Much and much functions will be valid to all our customers
Price 7000 Euro you can visit our website to watch the you tube video
(Limited quantity only)
http://youtu.be/0Ce4z8JY-go
•Mercedes W204 - ELV
•Mercedes C W204
•Mercedes CL W216
•Mercedes A W168
•Mercedes G W463
•Mercedes GL W254
•Mercedes GLK X 204 - ELV
•Mercedes GLK X 204
•Mercedes ML W164
•Mercedes W 207 - ELV
•Mercedes W 212 - ELV
•Mercedes W207
•Mercedes W212
•Mercedes G W463 (MOPF)
•Mercedes W221
•Mercedes SL R230
•Mercedes SLK R171
•Mercedes Sprinter
•Mercedes Vaneo W414
•Mercedes Viano W639
•Mercedes R W251
•Mercedes Vito W639
Dec 28, 2013 | 2004 Suzuki Forenza
Replacing wheel studs
The wheel studs are a press fit in the hub. You have to drive the old stud out with a hammer and punch. Sometimes if there is not enough clearance for the stud to be removed the hub has to be removed from the vehicle. You will need to drive the new stud in being careful not to damage the threads. Sometimes it is helpful to use a block of steel with a hole in it and use the nut to help pull the stud in. Keep drawing the nut while driving in stud with a hammer. After you are done and mount the wheel be sure to check the tightness of the wheel nuts a couple of times in the next 200 miles. Please rate my answer so I am awarded points for it.
Jan 25, 2012 | 2004 Kia Sedona
Electric windows in mercedes vito stopped working
Fuse has blown out. Check the fuse box under the steering wheel. The plastic cover has the diagram on the back, to see which fuse is for the electric windows.
Nov 20, 2010 | 2010 Mercedes-Benz Sprinter
Vw t3 rim size dimensions to fit other wheels to car
Mercedes is same bolt pattern but they use a 12mm stud/bolt so the holes need to be enlarged to 9/16" (14.28mm) for your 14mm stud/bolts.
This is not an exact fit but I have run them and it works dandy and the turbine wheels look great in addition to being about 1" wider so I can use lower profile passenger radials instead of the skinny reinforced ones.
Oct 12, 2010 | 1986 Volkswagen Wagon Camper
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
