When Start the xerox mechine ir 2870 it shows code E000225-0001
    Problem Solver:
  • 9 Answers
The light intensity of the CIS is faulty.
Disconnect and then connect the flexible
cable.
Replace the following as necessary:
flexible cable, CIS, reader controller
Posted on Jan 01, 2014
KyoDoc
  • 38 Answers
SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Posted on Sep 24, 2008
Cogz
  • 1326 Answers
SOURCE: Trouble with my canon copier ir 2870
E000602-0113 means that the hard drive is having problems booting up. You may try to remove the boot chip and clean the contacts with rubbing alcahol and reinstall it and turn the copier back on. Most likely you will need to replace the hard drive or try to re-flash the hard drive.
Posted on Mar 16, 2008
  • 2072 Answers
SOURCE: xerox error code u1-1 main motor fault
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
Posted on Jul 09, 2008
hamzaskilltd
  • 316 Answers
SOURCE: error code e000002-0000 canon ir 3300
fixing assembly low temperature
Posted on Jun 26, 2010
canontech
  • 1219 Answers
SOURCE: I have a caono IR
You need to replace fixing film.
Posted on Dec 28, 2010
2870 canon copier machine showing error code E000024-0001
service manuals free at http://www.eserviceinfo.com may help you out .
Jul 03, 2015 | Canon IR 2870 Digital Copier RECONDITIONED
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
remove your doveloper unit and check sensor, it is luse or re fix again ,........
Sep 24, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon 2870 copier showing error E000024-0001
open your developer unit and check sensor , refix it an close unit see........your problm solved
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
May 05, 2013 | Office Equipment & Supplies
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Ir 3300
E247 The software counter memory PCB and the software counter
value stored in SRAM are found inconsistent are you try to adjust the machine counter reading? That is Canon security features you cannot adjust counter by replacing soft counter board
Jul 21, 2009 | Xerox C2424 Copier
129 people viewed this question
k24674
