Question about AT&T ATT EL52500 DECT 6.0 5-Handset Cordless Phone With Digital Answering System, Silver/Black
Microphone on handset does work on outgoing calls
    Passionate:
    Visited the website for 10 consecutive days.
  • 177 Answers
Check to see if you have pushed the "MUTE" button... it turns
off the microphone, another press of "mute" turns the mic back
on, etc.
Posted on May 03, 2016
How can I record outgoing message?
Recording your greeting
message
1 {MENU} i {#}{3}{0}{2}
2 {V}/{^}: "Yes" i {SELECT}
3 After a beep sounds, hold the
handset about 20 cm (8 inches)
away and speak clearly into the
microphone (2 minutes max.).
4 Press {STOP} to stop recording.
5 [off]
Feb 14, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
HOW CAN I TURN UP THE VOLUME ON HANDSET. VOLUME IS SO LOW CALLERS CAN NO HEAR ME
There is no outgoing (microphone) volume control, if it is only your set try the handset from different extension. The microphone element may have been damaged (especially if dropped) and have to be replaced. Replacement handsets are not hard to find. If everyone on your system claims that callers cannot hear them, there are some settings on the central switch (KSU) which might help, but only after ruling out a problem on your particular set.
Jun 16, 2014 | Nortel Meridian M7208 Corded Phone
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Good luck from Headsets Direct!
Nov 03, 2010 | Plantronics Voyager 500A Deskphone Adapter...
How to erase incoming and outgoing calls in
go to resent calls and delete the incoming and outgoing calls
Jul 17, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-TG5632 one handset high pitched constant ringing
you are getting feed back because of too high of a level. Turn your volume down on that handset and the squealing should go away
Dec 27, 2008 | Panasonic KX-TG5632 Phone
Block outgoing calls
http://superphonestore.com/product_info.php?products_id=6495&language=en&cPath=8
This is bulky, but it will stop anybody from making an outgoing call unless they have a physical key.
Nov 12, 2008 | Cable_and_wireless CWD4901 Cordless...
Hi, I have purchased LG-RD3500 handset from Reliance Web world, Pune on 10th May 2008. Handset’s speaker has stops functioning while I was on call. This incident happened yesterday evening. Issue...
sir contact this address.. Shop No 10,Wadhawani Plaza,C/O Duotronix Pvt Ltd, Pimpri, Pune, 411018
09823905964... dont forget to rate me
Jun 26, 2008 | Cell Phones
No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
www.cordless-phones.uk.com
Jun 23, 2008 | NTL VS1500 Cordless Phone
You advice was such a blessing
Haven't experienced this one, it should open if you right click on the icon in the tray at the bottom.
However you should still be able to change your Skype options, click on "skype", then "Tools", then "Options", then "Audio Settings", change microphone and speakers to "logitech" or whatever your computer has listed your device as. This should have the effect of changing logitech to "use handset" and gets the same result. Unfortunately the phone will never work as good as it should, for instance I can't make test calls. I hope this helpful.
Jun 13, 2008 | Logitech Cordless Internet Handset Phone
Handset doesnt work
Do you have another phone (cell phone) you can use to make a test call to yourself? If you can answer a call and the Uniden transmits voice OK, then it is probably the speaker and may just be a bad solder connection. If the handset does not transmit or receive I seriously doubt you have a bad microphone AND a bad speaker, you'd be looking at something more serious.
Jul 25, 2007 | Uniden EXS 2080 Cordless Phone (EXS2080)
AT&T ATT EL52500 DECT 6.0 5-Handset Cordless Phone With Digital Answering System, Silver/Black Logo
52 people viewed this question
Top AT&T Lands Phones Experts
Computer Repairing
Computer Repairing
Art Cacella
BenjamineDupont
BenjamineDupont
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
