Question about Xerox WorkCentre 6605DN
No paper jam on workcentre 6605 but coming up as paper jam
  • 2072 Answers
SOURCE: workCentre XD130df
More than likely you have a bad fuser gear. It will break teeth, crack and not drive or the tab that inserts on the roller to drive it has snapped.
You have to remove the back cover to unplug the fuser then there are 2 screws that hold it into the frame.
The gear is on the right side of the fuser.
The price of the gear is less then 20 dollars.
Here is a link to a reputable parts source.
https://www.partsdrop.com/store/
Ask for Britt if you call. This is not me. Nor where I work. Just a reliable source.
Posted on May 02, 2008
  • 2072 Answers
SOURCE: Paper Jam or Will Not Feed
Sounds to me you have worn out feed tires.
Google a business called ' the parts drop. Give them a call.
They will have what you need, and at a fair price.
Posted on Jan 10, 2009
SOURCE: Xerox Workcentre 24- Paper jam in the fuser
Shut down. Unplug!!! Remove fuser to remove jam. Fuser may be or be going bad.
Posted on Apr 22, 2009
  • 239 Answers
SOURCE: I have a paper jam
If the paper is in the fuser area, the fuser needs to be taken out.
I have heard and seen some customers take out the fuser. It has two wood screws to be removed and the plug on the side.
Extra care needs to be taken when doing this task.
Unplug the machine.
remove the two screws and unplug the fuser plug.
Gentley pull out the fuser and you can see the paper in the fuser.
There are small stripper fingers down there, be very careful when taking partial pieces out, be very patient, and extra careful.
This roller does not turn very easy if you need to rotate it.
To reassemble, DO NOT OVER TIGHTEN THESE TWO SCREWS!!!"
Just tighten snugger than snug tight. Which means a loose tight. The mounting walls can break very easy.
If the problem jam is below by the tray, try to manage to push a card stock from below to get out the paper.
Let me know if this works.
Good luck.
Posted on Oct 16, 2009
SOURCE: My Xerox Workcentre copier gives an error message
I just had this same issue with my phaser3300MFP. Initially I thought this was a software issue but after careful inspection, there indeed was still a jam. I would check the fuser area of the machine. There is most likely a page jammed in that area and they can be hard to see.
Posted on Nov 25, 2010
Tray 1 has paper but gives error no paper
That's a common issue where the no paper actuator breaks. The part number is 120E33761.
http://www.iteminconline.com/120e33761_120e33761-xerox-6600-actuator-no-paper.htm
Jan 03, 2016 | Xerox WorkCentre 6605/DN Color Laser...
ERROR 024-959
Xerox 6605 paper tray empty error, the paper detect sensor arm and pick up roller get out of place. remove paper detect sensor arm and pull down on pickup roller assembly it should be springy not stiff. once it springs again, put paper detect sensor lever back on, on the right side of that lever gets tucked behind pickup roller assembly. hope this helps. The Magic Man!
May 29, 2014 | Xerox WorkCentre 6605/N Color Laser...
What is the cause and solution of a loud grinding noise coming from a xerox workcentre 6605 when printing
Sometimes when the toners get low on toner you will hear the gears grinding, or if there is an obstruction in the waste toner auger. Also check the drum units to make sure they are turning freely.
May 16, 2014 | Xerox WorkCentre 6605/DN Color Laser...
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Paper jams just as it comes out of the tray. It's
hi.have a look at your tray feed clutch.strip and cln
Nov 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Apr 22, 2009 | Xerox WorkCentre M-24 Color Copier
Jan 10, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre 6605DN Logo
1,663 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
