Question about Tablets & eReaders
Tablet reset button - Tablets & eReaders
    New Friend:
  • 126 Answers
What tablet is it
Posted on Oct 17, 2013
My tablet wont go pass go
works on most android tablets
some have reset hole with a button press that
if not turn off tablet
hold power button and volume down button till you see menu then reset
or hold power button and volume up button till you see menu then do factory reset. this erases everything on tablet
Jul 10, 2015 | Tablets & eReaders
Steps to reset tablet which is stalling up again
hard reset in android tablet PC's
different keys have hard reset in android tablet PC's
u can try like this method
  • volume down + home button + power button
  • volume down + power button
  • volume up + menu + power button
  • volume up + power button
  • volume up + cam +power
  • volume up + lock button + power
Hope this helps !
Dec 19, 2014 | Tablets & eReaders
How can I reset my Polaroid Tablet?
In the event that the tablet freezes or does not function properly, press the RESET button located on the bottom panel.
Follow the link to see the diagram of where to find the switch, it is in the bottom left corner of this web page. Zoom to maximum (200%) to clearly display the picture showing the location of the reset button.
The button is tiny, you will need to use a paper clip or the tip of a stylus to press the RESET button.
Data stored on the tablet will not be affected by using the RESET button.
The location of the reset button is the same on all models.
http://www.polaroidstore.com/store/images/pdf/pmid1000-polaroid-wifi-internet-tablet-with-touch-screen.pdf
May 24, 2014 | Polaroid 4.3" Internet Tablet
I need to reset my tablet
Hi Elena, you can follow this procedure to reset your tablet.
Turn off the tablet. Hold the back button and power button. This will take you into the recovery menu, use the volume keys to go through the menus. Select wipe data/factory reset and press the back button.
I hope this helps.
Apr 10, 2014 | Coby Kyros 7" Touchscreen Tablet
Frozen tablet
There is no reset button. The reset is performed by the power button, Press and hold for 6 seconds to reset the device.
Here is the manual
http://www.kocaso.com/manuals/M9300/M9300_User_Manual.pdf
Mar 29, 2014 | Kocaso M9300 Google Android 4.2 capacitive...
Okay i have to reset my childrens next7p12 tablets but i dont know how to reset
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 25, 2014 | Nextbook Tablets & eReaders
How to reset an emerson em744 tablet?
Mar 25, 2014 | Tablets & eReaders
I need to reset my kurio 4s
to reset this tablet, you have to hold the power button to turn off the device. Now you have to turn on the device by holding the power button and also the volume up button simultaneously. When you hold these two buttons simultaneously, you will be able to get a new menu. In this menu, there will be option for resetting the tablet. You have to select this option for resetting the tablet. This will ask you whether you want to confirm the reset of the tablet or not. If you confirm it, the data stored on the tablet will be wiped off and the tablet gets formatted. Now, the tablet will reboot automatically. After the reboot, you can notice that your tablet will be afresh and will be similar to the time when you have purchased it.
Make sure to take proper backup of the data present on the tablet before you chose the option of factory resetting or hard resetting. Take a copy of all the files in to memory card and remove it before resetting. In some tablets, there will be option of backup of files through syncing. If your tablet is having such feature, make use of it to ensure the safety of data.
Nov 03, 2013 | Techno Source Kurio Kids Tablet With...
Forgot my passcode symbol on my tablet an need to reset it please
This works with devices having physical home button
1.
Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory. With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Note: I Use My Tablet SUNBERRY, and reset my Tablet
Turn Off your Tablet and then
Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo)
Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog
you can see how to Reset android with video
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 14, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Where is the reset button for m729b tablet
The reset button should be on the top of the tablet and it should be silk screend on the back of the tablet as reset
Dec 28, 2012 | mid Archos M729B Android Tablet
Tablets & eReaders Logo
20 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
