Question about Sewing Machines
Viking e10 im threading wrong
2 Suggested Answers
  • 539 Answers
SOURCE: I need to know how to lower the feed dogs on my Huskystar Viking E10
There is a switch on machine to raise feed dogs up/down. Remove any extension table to locate it because many of these options are located in the back of machine & hidden by table! Jimmy :)
Posted on Apr 07, 2012
Apr 07, 2012 | Husqvarna Sewing Machines
Recently had Huskystarn E10 serviced. Now I am
Call the shop and tell them that since they serviced the machine, the bobbin will not wind.
Ask to have this fixed while you wait and not leave the machine.
Mar 02, 2010 | Husqvarna Viking 1
The bobbin is bird nesting on my viking emerald
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever and the bobbin is guided through the tension spring in the bobbin case. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 15, 2009 | Husqvarna Viking 1
HUSQVARNA TOPAZ 20 SAYS TO ENTER CORRECT HOOP. THE CORRECT HOOP IS IN THE MACHINE.
Your embroidery unit needs to be re-calibrated. Check your user manual to determine if that's something you can do. Otherwise, you'll need to have an authorized Husqvarna Viking dealer do the calibration and make sure the hoop sensor is working via the service menu. You can find authorized dealers close to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Sep 18, 2009 | Husqvarna Viking 1
I am searching for the User Manual Huskystar E10 model sewing machine. Do you have it?I need to know how to install the cotton correctly. Thank you!
Your Viking dealer can get it or you can call Viking directly and they will send you a PDF of it.
440-808-6550
Jul 11, 2009 | Sewing Machines
I have a Viking 6690. The bobbin tension is loose. How can I fix it?
when you say "bobbin tension is loose" do you mean that the thread bunches up under the fabric? If yes, then your UPPER tension is wrong and it's probably not threaded correctly.
Apr 17, 2009 | Husqvarna Viking 1
Problems with stitching
I think what you are describing is the bobbin thread is pulling up to the top of your work so the pretty side is getting ugly. If so, you may need to have the machine serviced and the tensions adjusted. You can adjust the bobbin tension, but if the problem is caused by a piece of lint or stray thread lodged in the proper place and it later comes loose, you just have to adjust it again.
Apr 07, 2008 | Husqvarna Viking 1
Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Apr 04, 2008 | Husqvarna Viking 1
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
