Control panel instructions for Blue sky BLF1270-7 machine
How do. Get volume on sky remote
for your tv?
http://help.sky.com/tv/your-sky-remote-control/program-your-sky-remote-to-control-your-tv
follow that link,follow instructions.done : )
Mar 19, 2013 | Televison & Video
Do you have the sky remote code for my LG 50ps8000?
hi,
sky remote control doesn't have code for ur lg tv. better u purchase a univesal remote control.
ok
Dec 15, 2010 | LG 50PS8000 50" HD Ready 1080p Plasma TV...
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Sky remote code for lg television model no.32pg6000 to programe remote controll on sky remote
Code is 1293 if you're using a Rev 8 remote control. You can check this on the sticker in the battery compartment.
If you are using an older Sky remote Rev 6, Rev 4 or plain old RC1600/00 then it's unlikely to work as these remotes aren't programmed to control your TV. You are welcome to try though ;)
Please post back if you need instructions on programming the remote.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | LG L3200AK Television
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
Jun 18, 2010 | LG 42LC2D 42 in. LCD HDTV
CANNOT FIND A CODE FOR LG 42PQ6000 TO OPERATE SKY REMOTE CONTROL. CAN ANYONE HELP PLEASE?
you will need make and model of tv
turn on sky and press interactive on remote move down to sky customer services and select then move down to program remote and select and follow on screen instructions
hope this helps
MERRY CHRISTMAS
Dec 15, 2009 | Televison & Video
Had sky + h d installed engineer does not no code twf tv
perss interactive on sky remote move down to sky customer service press select move down to program your remote you will need the manufacture and model number of the tv they are found on back of the tv once you have them folow the on screen instructions
hope this helps
Nov 14, 2009 | Sanyo DP26746 26 in. LCD Television
Sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Apr 26, 2009 | Televison & Video
Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
