Question about Music
I bought a XENYX 1832FX and only one channel is working on the main volume.. The led's on left side don't light up.. I have tested leads,speakers,and amp with an old mixer and they all seem to work fine has anyone come across this problem? I would really appreciate your input and help thanks
    Champion:
  • 243 Answers
There's a button named "Stand By" this is probably the cause of your mixer issue, just take the button cover up and insert the spray cleaner pipe inside and give it 2 or 3 shots, then push it in-n-out several times and re-check the mixer outputs, let me know a bit more to improve help.
Posted on Nov 04, 2013
  • 1 more comment
  • djchris Nov 05, 2013
    I will give it a try... I have ran canon leads to the mixer only one channel works... Then when i run jack to jack in the main volume both working but one not as powerful... And i have to press hard on the slider to get sound out of it... Hope this is more help
  • Power Electronics
    Power Electronics Nov 05, 2013
    Ok,
  • Power Electronics
    If you have to push the fader in order to get sound out of it then certainly you should change that Vr and if i remember right is a stereo pot with the 20kx2 value, hope this helps, i'll wait for your response, thanks.
4 Suggested Answers
  • 5603 Answers
SOURCE: I have a behringer xenyx 2442 and the main output
The utput fader has probably been broken. If the knob takes a hit, it breaks the resistance element. The part is inexpensive but it takes a lot of work to access and replace the part.
Posted on Jul 17, 2010
  • 5603 Answers
SOURCE: how much output power supply
The supply will be similar to that in the 1222. Download a schematic here. Look at the SPUS2 portion of the compressed file.
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
There are several voltages present.
Posted on Jan 20, 2011
  • 5603 Answers
SOURCE: Good evening, I bought a second hand Mackie mixer
With LED intensity changing with operations, that MIGHT be a symptom of the power supply going into current limiting mode.
The first thing I would do is to check the power supply voltages with an oscilloscope to assure that the voltages are stable and not dipping...
Now from my experience when I hear that a transformer had to be replaced that means it suffered over voltage or under frequency. I would IMMEDIATELY suspect that one or more of the rectifier diodes might be open. With only half wave into the caps the voltage will dip below what the regulators can handle giving weird effects. Check the +/- 16 volts with a scope that they are PURE DC and don't have ripple due to either damaged diodes or C6 or C7 being degraded. I assume you have a schematic... if you don't here is a link:
http://elektrotanya.com/mackie_1604-vlz-pro_mixer.pdf/download.html
Posted on Jan 29, 2011
Mixer Switch on and after a short period theres a noise that sound like a machinegun and a Hiss sound through the speakers
I assume that the power-amp is good.
This noise, of course due to defective parts inside.
But, which section is it? Chances are:
  • Amplifier circuit in the Main-Outputs. If the MAIN MIX in the minimum position and still noisy, then the damage in that section.
  • At one or several channels. Let's test.
    Set to minimum volume for all channels and MAIN MIX. EQ=flat. FX=minimum. TRIM at half (let's try at 12 o'clock).
    Raise the MAIN MIX, let's say at 15.
    Gently, raise channel 1 volume to maximum, listen, if there is no noise, channel 1 is safe. Lower the volume to the minimum again. Move to another channel in the same way.
    If found noise, that is where the problem is.
Actually, many more detailed steps for testing, but the description is too long. This above is a simple way.
Circuit power supply should also be checked, whether all normal voltage.
It is part of the image of the amplifier section circuit.
Parts which may be broken is the IC 64,65,77.
Sep 13, 2015 | Behringer XENYX 2442FX Mixer
Clipping always lit
  1. Make sure nothing is plugged in.
  2. Turn the GAIN, LEVEL, and FX knobs for each channel, counter-clockwise all the way.
  3. Bring the MAIN fader all the way down.
If the signal LED's above the MAIN fader are still lit, then the board most likely has a short in it and will require repair.
If the signal LED's are dark, repeat the following on each channel...
  1. Rotate GAIN clockwise until the mark on the knob is at "12 oclock".
  2. Rotate LEVEL clockwise until the mark on the knob is at "3 oclock"
  3. Raise the MAIN fader to "0".
  4. Check LED's - if they light up then the channel you are working on is "noisy" or has a short in it.
  5. Return GAIN, LEVEL, and MAIN to "all off".
  6. Repeat with next channel.
Jan 25, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
How to connect it ?
Instructions
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Jun 19, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
Left side output not working.i get no lights on left sde
Try headphones... do you get sound both sides (assuming your PAN controls are centered.???
Now do same with the main output cables discoonected... do you get headphones both sides???
Next solo or PFL a channel... do you get sound both sides???
Answer me these as they are tests that I can do some isolation using the circuit schematics. Make sure to answer all three conditions.
Jul 16, 2011 | Behringer XENYX 2442FX Mixer
How much output power supply behringer xenyx 1832fx?
Jan 20, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
When you use the input from CD how do you get it to be heard on the speaker?
Right next to the master leds there is a knob directly right of that is a 3 way push button switch push in cd/tape and the level is off of the knob. Good Luck, Cody J.
Dec 20, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Output form computer to board using USB works but the signal for input doesn't work
In the control panel, "sounds and audio devices" under the "voice tab" make sure the INPUT is set to the Xenyx device.
Dec 01, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
My macbook pro will not identify the usb mixer. it said the mixer would work with a mac or pc, so what can i do to make them compatible?
hello, I have a behringer 1832. the issue I have is that the right channel is out all together. both subs work. it is only the right main. do these things have some sort of mono switch that I don't know about?
Nov 21, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Music Logo
59 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
