Magenta toner sensor error oki intec cp2020 - Office Equipment & Supplies
Touch2Heaven
  • 145 Answers
SOURCE: toner sensor error
The toner cartridge has a small window from outside where the dark blue handle. You should turn a photodrum gear wheel while the window will not open. After that insert a drum unit and work.
If you have "start cartridge" that doesnt work....
Posted on Oct 18, 2008
charcois
  • 763 Answers
SOURCE: OKI C3530N
try check if it fits the cartridge to the printer correctly it must have been loosed while printing. Ask the shop about the cartridge that youve bought from them and ask for replacement maybe its just a factory defective.
thank you for using fixya
CHARCOIS
Posted on Oct 31, 2008
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
  • 22 Answers
SOURCE: Machine flashing K Toner Sensor Error - how do I
See if this works - switch off at mains, pull black toner part way out, push back in, switch on again.
Posted on Feb 21, 2010
take out the magenta cartridge. and make sure the edges are clean. There are little metal pieces on the sides where the sensor reads the cartridge. Also, make sure the "lock" on the cartridge is locked.
Posted on Jul 23, 2010
HELLO. My oki c9600 gives me an error code 145. I Allready replaced the magenta id unit But the error is still on. Can somebody give me a hint? Regards from germany
Was ist los, Kamerad?
An error was detected with the magenta toner supply mechanism sensor; if rebooting the machine does not improve the symptom, you need to check the device. This does not necessarily mean that the toner cartridge is defective nor empty but that its sensor is not detecting it. Use a clean, dry Q-Tip (cotton swab on a stick) to clear toner dust from the gold contacts.
Dec 02, 2014 | Office Equipment & Supplies
Why do I get: an error has happened to Magenta toner sensor?
open top cover, take out toner, on left hand side there is a photo eye that detects the that the toner is locked into the drum unit. clean it with canned air
Jun 28, 2014 | OKI C3100 Led Printer
Chip intec
this company sells refills and chips
http://www.zinetic.co.uk/CP_2020-list.aspx
Sep 27, 2012 | Office Equipment & Supplies
I have no Oki, i have Intec CP2020 and I see that they are pretty much the same printer. So, I have problem service call:175 fatal error, it says. Any ideas? Thanx
i have intec cp2020 machine showing error code close the frond cover error code 330.already closing frond cover.what is the problem machne i will wait for replay.i will check the pwersupplay board & fuse
Nov 20, 2010 | OKI C9600n Led Printer
Toner sensor error
Jul 22, 2010 | OKI C9300 Led Printer
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
LED Head Missing, Color:Magenta
Take out the magenta cartridge to the right upper indside wall of the printer you should be able to see a small rectangular window, give it a blow of wipe with a cloth, do the same to the corresponding part of the m toner, put the drum and toner back, shut the lid and everything should be ok. If not contact oki for a replacement drum/cart.
Mar 23, 2009 | Office Equipment & Supplies
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
97 people viewed this question
jasbo
jasbo
