Why do i have to keep pressing reset button on boiler
    Champion:
  • 219 Answers
Could have an internal malfunction that it is detecting and going into fault mode.
Posted on Oct 17, 2013
Remeha boilers - pilot light keeps going out
You Need to replace the Thermocouple. You can get them at most hardware stores take the old on with you
images?q=tbn:and9gcs197mmasu0-olkj-42wttmbnfimgyu0r1wy_jdi-wq-_xsajtbwq
Nov 22, 2012 | Water Heaters
The boiler keeps cutting out and radiators cool down Sometimes we have to press reset button for hours before we get it going again .
Sorry but you have posted on the washing machine forum and I'm not sure anyone will be able to help you ;-0)
Having said that, would you believe this morning we had a delivery of oil and switched the boiler off for a couple of hours as per instructions. When I restarted it, it ran for a short while and stopped. With our boiler the oil injection/blower/electronics box has a red light around the reset button and how it flashes together with the number of times it flashes after each stop indicates what the problem is. Ours flashed 4 times, paused then repeated. If your reset button also has an indicator light illuminating it, does it flash in a similar fashion? If so I would write that information in your re-posted problem so that someone has more information to go on.
Sorry for the 'rant'!
Good luck,
John C
P.S. the problem turned out to be one of the smaller PCB's in it!
Feb 28, 2011 | Bosch Washing Machines
The boiler stopped twice during a week. The reset button was pressed whenever to start the boiler again(twice during a week). Is it abnormal? Does the reset button need to be replaced?
Good Question!-- Let's see if we can figure this out--
What kind of fuel are we talking about? - Gas or Oil?
Any clue as to WHY the boiler stops?--
Can you see a water level, or a temperature or a pressure setting/ gauge?
Tell us what some of these readings are--
If it is gas-- how does ignition take place?-- Spark, or ignitor ignition?
Where is the Reset button?-- is it on the burner control-- or the water level control?
Tell us more--
Mack B
Jan 17, 2011 | Heating & Cooling
I have worcester boiler 24i it would not fire when central and water is turned on the light is on the presure is ok pls help
Look either on the top left of the boiler, outside
Or remove front panel and look bottom inside left of chassis
You should see a small red button. This is the reset button. Press firmly [sometimes these gum up and may need hard press] and try the boiler again
Mar 28, 2010 | Heating & Cooling
I HAVE A HALSTEAD ACER HIGH BOILER AND IT IT IS SAYING LOCK OUT ON THE BOILER WHAT CAN I DO TO FIX IT
The overload button is on the left underside of the unit. There is a finger sized hol and the button is in there. Once you have reseet the button you will also have to reset the boiler by using the switch on the control panel (furhtest left switch).
Dec 03, 2009 | Water Heaters
My boiler will not reset and the green light keeps flashing
The nozzle on the burner is probably clogged. Have a service tech who is qualified look at the burner. Pressing the reset button repeatedly will fill up the chamber with oil and create a dangerous situation.
Apr 01, 2009 | Water Heaters
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Bosch boiler System
it means that the boiler wants to be serviced, the boiler will still work fine. Once the boiler has been servcied, there are a succession of buttons, that need to be pressed, to tell the boiler that it nhas been serviced. then 365days after it will do it again. Its there to prompt you, to get the boiler serviced
Dec 11, 2008 | Water Heaters
22 people viewed this question
jasbo
jasbo
