Television X Codes
Where can i find frequancy KHz for my tv
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
Check the specification page of the user manual to your TV for details.
Posted on Oct 17, 2013
Pcm 48 khz
mine does the same thing. I found a pdf of the manual and it said this in the troubleshooting section:
""PCM--kHz" appears on the display. , The sampling frequency is more than 48 kHz. Change the DVD setting to 48 kHz."
I have my seiki tv hooked into the dvd/ld input through a coaxial cable, and I don't think my tv has a setting to change the sampling frequency. so I have no idea what to do. any help would be great!
Jan 15, 2014 | Sony STR-DE445 Receiver
Sony Bravia - sound pulsates off and on - several minutes on and then 10 seconds off. We checked cable box and HDMI cord on another TV, and sound was fine, so narrowed down to the Sony Bravia.
Actually try one more thing before concluding that there is something wrong with the sound board or one of the wires in it on this Sony Bravia television. The cable box settings might not be just right for this television. Are you currently set to pcm or bitstream on this cable box? pcm might also be displayed as 2 ch 48 or 96 khz. Play around with the sound settings and see if one or the other will solve this sound issue before writing off the television.
Dec 01, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
How to get MPEG4 on 42lg7000
Purchased music files(*.MP3) may contain copyright restrictions. Playback of these files may not be supportedby this model.
Music file on your USB device can be played by this unit.
The On Screen Display may be different from your TV. images are an example to assist with the TV operation.
MUSIC (*.MP3) supporting file.
Bit rate 32 to 320
Sampling rate MPEG1 layer 3: 32 kHz, 44.1 kHz, 48 kHz.
Jun 21, 2012 | LG 42LG7000 42 in. HDTV LCD TV
The horizonal hold is not working it rolls up and down
I understoof about your problem of Mitsubishi CS-35503* TV , I think you should change your interlace scanning frequancy by remote control t0 50Hz
if there will not effect then change your horizontal hold IC
Thank you!!
give your rate!!!
Feb 20, 2011 | Mitsubishi CS-35503 TV
I am student of BE 2nd year and i dont know that how to find frequancy response by using proteus so plese help me and sent me process of finding frequancy response i...
i don't know much about finding frequancy but i can help you just go through this links
http://mic.sgmjournals.org/cgi/reprint/87/1/173.pdf
http://ajol.info/index.php/ajb/article/viewFile/59935/48207
http://www.rjbaudio.com/Proteus%20jr/proteus.html
thanxs
Oct 29, 2010 | Computers & Internet
Remote won't work with tv.
You can cheque the remote if you have a Medium wave portable radio. MW range 550 kHz to 1600 kHz..
Tune the radio towards the 550 kHz side. Now take the remote near the radio and start pressing the keys. You will hear a whizling sound. This shows remote is functioning. No sound! check the remote battery compartment. May be the leaked battery acid would have spoilt the remote circuit PCB.
If you can dismantle the remote, you can wash the printed circuit board in running water several times. Dry with air dryer and give a try. Good Luck!
Mar 30, 2010 | Sanyo DS27930 27" TV
The at&t remote will not control the on and
check the remote control.
Take the remote control nearer to your portable radio. Tune to the MW range 550 kHz to 1600kHz. Lower end prefered.
Press the keys you will hear a sound. Press on/off and see whether you get this sound. If no sound you have check the remote pcb or the key board mat.
Mar 29, 2010 | Maxent MX-42XM11 Television
While connected via VGA cable Viewsonic VG920 Monitor has an error stating "out of Range" . H. Frequency 157 Khz V. Frequency 59.8 Khz
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory set to connect directly to a television with supplied RCA cable. Do that before you connect to a VGA monitor. Using the remote control, press setup and then go into "preferences" and look around for "video" and then to "VGA". Once you click "VGA" the TV screen goes frighteningly blank. The next obvious step is to hook it to the VGA cable and VGA monitor. If your computer is also hooked up and on to the monitor there is no karaoke picture. Shut off or disconnect computer and presto, there it is. <br>
www.texsax.com
Dec 13, 2008 | Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/...
Ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Feb 06, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
