Question about LG Washing Machines
1E error on lg wf-764wf? - LG Washing Machines
  • Marek
    Marek Oct 17, 2013
    Sorry - just adding further details. When I switch the machine on, it appears to be trying to work but then doesn't fill up with water. Eventually I get the 1E error. If you can help then that would be great.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Not enough water . check pressure check strainer at the back ot the machine where the hoses is connected.
Posted on Nov 06, 2013
Showing a 1E error code
You need to post more info like a model number
Aug 29, 2016 | LG Dishwashers
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
LG Tromm wm1815cs front loader washer error message 1e. Have cleaned filters, checked hoses,and supply source, I still get message,
R u sure it is not an (LE) error code. Kinda looks like an upside down (F)? Very common on older LG washers. Indicates a hall sensor/ motor position sensor error.
Mar 22, 2015 | LG Washing Machines
WHAT DOES ERROR MESSAGE 1E MEAN AND HOW DO WE FIX IT?
On LG's, a 1E error message usually means there is a problem with the water inlet valve. Check your shutoff valve under the sink, first, just to make sure someone didn't accidentally turn it off. If it's on, then it's most likely the water inlet valve located under the dishwasher.
Oct 18, 2014 | LG Dishwashers
LG fuzzy logic 7.5kg WF-T753A, 1E code coming up.
water is not enough check for obstruction and water pressure
Sep 28, 2013 | LG WD-14124RD Front Load Washer / Dryer
My lg wm12225fd direct drive error 1E
Is it 'IE' ? There is no '1E' error code. Input error. Is water turned on? Are waterline filters clear, the ones between the hose and the unit?
Apr 07, 2017 | LG Washing Machines
Lg washer wm2277
The "1e" is actually a LE or Load Error. Search for it on this site and you will find many responses covering it. Some can be somewhat serious, but the most common cause is drag on the drum due to too much and / incorrect soap. Always use HE (high efficiency detergent) and no more than one tablespoon per load.
Sep 13, 2008 | LG WD-1280FHD Front Load Washer
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
