Question about Accutemp Steam N Hold Convection - 348137
Steamer only reach 190 degrees and the thermostat range is 300
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
THERMOSTAT IS DEFFECTIVE REPLACE WITH SAME
Posted on Nov 08, 2013
I have adjusted my oven 30 degrees higher but is still lower than it should be by about 20 degrees do i just live with it or what
In fact, +/- 20 F degree is not big problem when the oven reaches 300 or higher. If you feels concerned, the oven thermostat is the culprit.
Thanks,
Sep 18, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
2003 grand marquis trouble code po 128. Heater works. 100 mile trips no problem. Temp gage below C. New sensor or new thermostat?
Well code 128 is for a thermostat problem in the fact the engine is not reaching normal temp. If you have heat the engine is warming up but still may not be getting to normal range. Normal is 190 - 210 degrees.
I would replace the thermostat first and see what happens.
Jan 24, 2014 | 2003 Mercury Grand Marquis
Thermostae
Maybe.
If the cooling system is working correctly, the only thing the thermostat does is make the engine reach normal operating temp in a short period of time. The engine is designed to run at 190 - 210 degrees as much as possible.
If you leave the thermostat out, it may run cooler, but you will get a check engine light at some point in time if the engine does not reach 190 degrees within 5 or 10 min. And when the check engine light comes on the performance will drop off. And it will use more fuel.
Jul 20, 2013 | 2005 Acura TL Automatic
What is the normal operating temperature for a 2003 Chevrolet Impala with 3.4L engine? Mine use to be around 185 to 190 degrees on the gauge inside the vehicle. The gauge now can range from 200 to 220...
The range should be in the temp range of your thermostat within in a few degrees, you probably have a 190 degree thermostat. As the outside (ambient) temp rises it's normal for the engine to run a little hotter 200 degrees is safe with coolant, water boils at 212. Your fans should cycle, so it sounds like your temp sensor is faulty. if you haven't flushed your radiator and changed your thermostat lately, now would be a good time to do so. Hope this helps,
Jul 16, 2011 | 2003 Chevrolet Impala
New water pump, bypass hoses on a 2002 buick lesabre, but vehicle still runs between 200 and 209 degrees! Is it normal for the temperature to fluxuate in that range or is the thermostat bad??
The thermostat for that vehicle should be a 190 or 195 degree rating. If your temp is moving up and down by only 9 degrees then the thermostat is probably ok. You might check your coolant level and make sure that it is at the proper level and that all of the air has bled out of the system. Do this when the vehicle is cold and never open a coolant system on a vehicle when it is hot.
May 08, 2010 | 2002 Buick LeSabre
2000 Dodge Caravan 3000CC engine - In summer, temp gauge in the center. Water temp is 190 degrees. In the winter, temp gauge at quarter level. It takes forever to rise. If you use the heater, the temp in...
Sounds like a stuck thermostat. The thermostat cycles open and closed in order to maintain a temperature range, some cars with very sensitive gauges reflect this opening and closing, but most cars have gauges that are somewhat less responsive in order to keep people from thinking something is wrong. I would defineately replace the thermostat and flush the cooling system, replacing the fluid with fresh.
Dec 22, 2009 | 2000 Dodge Caravan
Check light on Chevy Malibu 2002
P0128 - Coolant Thermostat Below Thermostat Regulating Temperature
REPLACE THE THERMOSTAT THE ENGINE IS NOT REACHING CORRECT OPERATING TEMPERATURE, 190-195 DEGREE'S FAHRENHEIT.
Feb 17, 2009 | 2002 Chevrolet Malibu
Accutemp Steam N Hold Convection - 348137 Logo
50 people viewed this question
Top Accutemp Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Accutemp Kitchen Appliances - Other Expert? Answer questions, earn points and help others
