I recently cleaned my laptop aspire 3000 motherboard and checked my speakers now its not powering on but shows that its charging.when i try to switch it on the charging led turns off and cpu fan only ticks and lights flash then nothing happens.i used a blower meant for that.wat can it be
  • 29 Answers
Some static electricity was generated by the blowing and your motherboard was damaged. If the computer is still under warranty you might be able to get the computer repaired. If not, and If you have the expertise you can order a replacement motherboard and replace it yourself.
Posted on Oct 21, 2013
5 Suggested Answers
nai6378
  • 58 Answers
SOURCE: AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
Posted on May 10, 2008
  • 50 Answers
SOURCE: Dell Dimenion 3000
sounds like you need a new motherboard. Try to reset the bios with the jumper (or remove the battery and unplug it) and see if that does anything, if it doesn't start looking for a new mb.
Posted on Jun 04, 2008
SOURCE: No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Posted on Jul 05, 2008
Danmart
  • 291 Answers
SOURCE: Computer won't boot. When power
1st. check your memory sticks, if you have two, flip\flop them around. if you can replace (don't buy them if you can until you are sure that they are damaged) or substitute them for a "lower" value & frequency range. Just to see if the computer turns on.
p.s. are putting the computer together for the 1st time?, Was the computer working before the problem? if so you could have said so!
Posted on Dec 18, 2008
Aspire series 3000 will not stay powered on...it powers off before operating system loads and before cd-rom disc can load. I have confirmed that the battery receives/holds a charge and even swapped out...
Ram problem? Try replacing the ram modules, to see if they are causing the problem
Then see if the power switch is sticking, or the small cut off switch on the top of the laptop near the hinge is jammed.
Other than that, I think you may have either an overheating problem (strip laptop to check), or a faulty powerboard component, as you have tried the obvious solutions already
Jun 15, 2011 | Acer Aspire 3000 Notebook
As soon as the power supply was connected and switched on, the motherboard would power up and the fans would spin.. all hard drives/optical drives etc would turn on. But there was no post, or beeps, just a...
Sounds like you have a short in your display plug or the display itself.You also should try different or new ram sticks to eliminate ram as the cause.Try an external monitor also to see if there is any video showing.Technicians seem to always say the motherboard is bad to get the most money when the motherboard most of the time isn't bad its whats connected to it(ram,display,cd/dvd drives etc.
Jul 01, 2010 | Acer Aspire 3000 Notebook
The battery won't hold a charge. it's a brand new
Have you checked the pins (the points that the battery takes power from the laptop)? Try cleaning them with alcohol and check loose contact.
Try these and in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 08, 2010 | Acer Aspire 3000 Notebook
Battery will not charge
Most likely the problem is your ac adaptor on your motherboard. If your battery is completly dead pull on the adaptor (where you plug your cord into your laptop) and continuously press the power button if it powers up this is your problem.
When pulling on the cord try every angle possible.
Oct 18, 2009 | Acer Aspire 3000 Notebook
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
Sep 13, 2009 | Lenovo 3000 N200 Notebook
I have Acer Aspire ONE 8.9" but and it is
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 30, 2009 | Acer Aspire One AOA150-1784 Netbook
Computer shutting down
  1. Be sure your power supply is working and charging battery
  2. Allow battery to full charge
  3. Be sure PC is cold not hot or warm
  4. check if before shutting down PC fan is starting: if not starting PC thermal protection can be triggered and your fan out of service.
Jan 14, 2009 | Acer Aspire 3000 Notebook
Weird noise from Acer Aspire 3000
When you open the sound control panel, is the mic muted or turned down? The feedback may have been coming from the built-in microphone?
Jul 16, 2008 | Acer Aspire 3000 Notebook
Acer Laptop does will not switch on.
Good morning!
Have you actually checked the output of the powerpack with a meter? Then, check your power input jack, where you plug in the power pack to the laptop. It may have come loose and need to be resoldered, or replaced.
Ron-
Feb 28, 2008 | Acer Aspire 3000 Notebook
Acre Aspire -- 3000 series notebook -- Power adapter issue
It's a loose connection on the motherboard. The power connector on the motherboard will need to be re-soldered. You really don't need a new motherboard. You need to find a good Technician that can do this. I use to do this at my old job. We charged $65. Some places will charge up to $90 or so.
Jun 29, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
