Motherboard plug Where screen p;lugs into Motherboard on 2007 Macbook Pro came lose from Motherboard. How to cixc. No problem if this is a permanent fix irreversible.
  • James Miller Oct 26, 2013
    use acid cleaner to clean then use the best acid solder to do the job
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Solderer it back in
Posted on Oct 26, 2013
  • mac nut lost
    mac nut lost Oct 26, 2013
    What I Thought, but IT Pro friend said had to be micro-desoldered then micro-soldered in and no guarantee that'll work-I'm taking it apart again and remove old solder and trying the simplest way-makes sense to me as well-thanks. I needed to hear the simple way was right way from someone else also.
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: The mother board is shot
Yes. Nvidia had a rash of problems with the GeForce 8600M GT GPU, that was installed in MacPro 2007-2009 models.
[GPU. Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU ]
1) Here is a link to free Service Manuals for the Apple Macbook's.
MacPro 2007-2009. 15 inch, and 17 inch,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-apple
You didn't state whether your Mac is a 15 inch, or 17 inch.
To the right of the heading - Macbook Pro 15", or Macbook Pro 17", left-click on the file heading which matches your laptop.
[For example:
If you know that your Macbook has a 15 inch LCD screen, 2.2GHz, or 2.4GHz processor, and was made in 2007, to the right of Macbook Pro 15" you would click on - 2.2/2.4GGHz 2007 ]
This is a PDF file.
Ordinarily it takes 10 to 20 seconds, to download an average PDF Service Manual, for me.
I usually advise that it may take up to 30 seconds, with additional time may be needed to fully download the file.
The Macbook Pro 17" 2.2/2.4GHz 2007 file took almost 2 Minutes.
Tools:
A) No.1 and No.2 Philips head screwdriver. NON-MAGNETIC
B) Tweezers
C) An unused thick plastic credit card
D) Apple 'Black Stick'.
Or properly referred to as Nylon Probe/Spudger Tool.
http://eshop.macsales.com/item/Apple/9225065/
Why?
Because it will make your life SO much easier when disassembling.
The top large plastic cover of your laptop under the Keyboard, (Top Case), is attached to the Bottom Case, via a bunch of plastic snaps, after the screws are removed.
The plastic snaps are formed out of the plastic of the case, and are spaced around the side edges.
They are flat tabs with a small hooked end. As the Top Case is removed from the Bottom Case, the tabs snap, snap, snap as they come loose.
For your first time it may set your nerves on edge as you might think you are breaking something.
The 'black stick' is shaped so that it can be inserted into the parting line of the two case halves, and slightly twisted.
The shape of the 'stick' pries the two halves apart from the twisting motion.
There are also delicate small wires that may be damaged if a metal tool is used, plus the Logic Board. (Motherboard)
A plastic tool is best used, plus the shape of this particular tool makes it a gotta have.
(Plus it's Cheap)
E) ESD Wrist Strap. (Electro Static Discharge)
You MUST use this tool.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Relieve your body of Static BEFORE working on your computer.
The alligator clip of the ESD wrist strap is connected to a good ground source.
(I connect to the metal frame of an empty desktop computer case.
I realize that not everyone has one of these babies sitting around.
Perhaps you have a large metallic object you can place on your worktable. Large metal serving tray, or large metal knickknack)
Example of an average ESD wrist strap,
http://www.newegg.com/Product/Product.aspx?Item=N82E16899261001
A LOT of stores carry them.
F) Multi-compartment container.
Label each compartment for the area the screw/s come out of.
Some screws look VERY similar to others.
Do Not mix them up!
You can use a clean egg carton if no multi-compartment container is available.
Label each egg holder.
G) Record:
Make notes, and drawings as you disassemble. Perhaps digital photos, or camcorder.
Nothing like having a record to refer back to in case you are interrupted.
Also nice to have a Personal record made by you. Your notes, your handwriting, etc.
{Tilt the motherboard to install it}
After you have the motherboard (Logic Board) in place, you will need to clean the top of three chipsets. (Chip)
Processor, GPU, and third chipset.
Use an old credit card to scrape off the most of the thermal paste. Wipe the old thermal paste on a clean rag as you scrape it off.
Now use Q-tips dipped in Isopropyl Alcohol. It will take a bunch of dipped Q-tips. The tops of those chips needs to be clean enough to eat off of. (No kidding)
NO old thermal paste, or a thermal pad, must be present.
(A thermal pad is a cloth soaked with thermal paste. Highly inefficient, and CANNOT be reused anyway. If there is a thermal pad on one of those chips, carefully peel it off. Soak the remnants left behind with alcohol, then use the credit card. Keep using both until the thermal pad is completely gone))
Apply one small pea-sized drop of thermal paste to the Center of each of those chips.When you set the Cooling Tube down, and lock it into position, the thermal paste will squish out just right.
A note on using Artic Silver thermal compound:
Artic Silver (5) has real silver in it. Silver is a Good conductor of heat.
It is also a good conductor of electricity.
If you use too much it will ooze off of the chipsets, when they are fully warmed up. It then oozes down onto solder joints, and creates a Short Circuit. Bye-bye computer.
Applying thermal paste properly,
http://www.hardwaresecrets.com/article/How-To-Correctly-Apply-Thermal-Grease/274
If you have ANY questions do not rate this until you are finished asking. State your questions in a Comment.
Regards,
joecoolvette
Posted on Aug 12, 2011
willem52
  • 359 Answers
SOURCE: can't connect monitor to MA770-ES3 motherboard
The 9 pin port on the backplate of the mainboardc is NOT for monitor screen, but is a serial port.
You need a PCI-e Graphicscard to connect your monitor screen.
Be certain that the graphicscard does have a 15pin sub-D port.
Most newer cards do have DVI and HDMI, some also have 15 pin sub-D.
Posted on Oct 21, 2011
MacBook Air intermittent back page function
It was the most common MacBook Pro intermittent black screen problem may be due to motherboard out. Get contact with your nearest Apple Store and Fix it. Follow http://support.apple.com/kb/he5 to see your country Official Support Contact list and for more help
Apple Customer Support .
May 24, 2014 | Apple MacBook Air
CLOUDY MACBOOK PRO SCREEN
screen probably needs replacing. There are no major known symptoms for cloudiness in macbook screens.
Mar 11, 2014 | Apple MacBook Pro Notebook
Video issue macbookpro 2006
startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Jan 02, 2014 | Apple MacBook Pro with 17" Display
Macbook pro 17" checkered screen
It is likely a solder joint gone bad between the GPU and the board due to more ecologically friendly but more brittle non-lead solder. You can either take the computer to an Apple store and consider the cost of having the motherboard replaced (roughly $600) if it's no longer under warranty, or search for local technicians who are familiar with "reballing" the GPU (which shouldn't cost more than $200US). Be aware that a replaced motherboard may just be a swapout from another MBP manufactured under the same conditions. Read this article for more information. Class Action Lawsuit Filed Against Apple Over 2011 MacBook Pro Graphics...
Jan 18, 2013 | Apple MacBook Pro with 17" Display
My screen blinks and go off in my macbook pro this is fourth time it happened 15 inch 2.53 ghz intel core 2 duo i took it to expert apple store they run some test and told me take it home and try for a...
Try a firmware update. Plug in the power, remove the battery and startup the Mac but hold the power button down until you get a loud BEEEP and the lights flash repeatedly, and let it do it's thing. That will reset the motherboard.
If that doesn't do it, it's hardware (screen, Cable or Motherboard) and better for Apple to sort it out (Usually for free)
Jul 23, 2010 | Apple MacBook Pro 15inch Notebook 253 GHz...
ASUS monitor is plugged into MacBook Pro. Has worked fine over the last 12 months with both screens working independently. Recently unplugged for 2 months. Plugged ASUS back in. After approx.5 minutes, the...
(1) If you have connected windows cpu to monitor then when you power up the computer press F8 key then enter in enable vga mode then go to control panel ->display property -=>settings change screen resolution to 1024*768.
then check .
(2)But if you are not able to see any display on screen then open cpu cabinet and refix ram memory pull cmos cell from motherboard for 10 minutes ,if there is any pci card or vga card installed on motherboard reattach it into motherboard.Then check.
If you have mac book then follow my second solution.
Let me know if you need further assistance.
Thanks for using Fixya.
Apr 07, 2010 | Computers & Internet
Macbook chip shim
Thias can also come from a dead hard drive, or a dead backlight (screen).
The best test would be to plug an external monitor to see if something shows up. If yes, that would mean that the backlight doesn't work anymore. If not, then you have an other hardware problem (motherboard, hard drive).
You can check if the hard disk is the problem by removing it. You should then see a flashing question mark and the screen on.
Keep in touch ;)
Jun 25, 2009 | Apple MacBook Pro Notebook
Reconfigure a macbook pro to install a larger hard drive
I would suggest going to an Apple store and asking the folks at the genius bar. I'm not sure if you want to try and reconfigure your motherboard by yourself.
Aug 28, 2008 | Apple MacBook Pro Laptop Computer with...
When turning on my macbook pro
Does it work with an external?
1) If it does boot through external. Your LCD, LCD inverter, or LCD cable may need replacement.
2) If it does not boot, then it may be problems with video card or motherboard problem. May need motherboard replacement.
Please let me know the follow ups of it. Thanks!
Mar 03, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
