Question about As Seen On TV H2o Mop X5 5-In-1 Steam Cleaner With Elite Accessories
H2o x5 mop leaking
Water and big burst of steam comes out of the overflow hole but not much comes out where meant to on floor.
One of the silicon tubes have split inside my steamer. Where can I get replacements please?? Thank you..
notify or look up manufacturer and check for parts number and if they sell the part / or for the distributor in your area that carries parts
Repairing an H2O Steam Mop
Aug 27, 2016 | Thane H2o Mop X5 5-In-1 Steam Cleaner
My h20 steam mop dripping water from small hole underneath
Stuff bought from "As Seen On TV" are, generally of very bad quality, would even say, thet are scam! Parts to are not available and actually no one knows how to repair them.
OK, just my personal experience and opinion; decided not to buy anything from thwem any more..
Keep on your query for help
Aug 09, 2015 | As Seen On TV H2o Mop X5 5-In-1 Steam...
When I turn on Red light then green light and no steam or no noise at all.
Try vinegar in the unit first. Let it sit overnight then turn it on and test. If it still won't steam, try CLR 1:1 ratio and repeat steps above. Repeat until unclogged. Use ONLY distilled water in your unit going forward.
Mar 19, 2015 | Thane H2o Mop X5 5-In-1 Steam Cleaner
X5 H2O Steam Mop dripping water from small hole at bottom and not producing much steam
john, I would try cleaning the mechanism with vinegar or CLR to dissolve any buildups you can't see. Rinse, fill up with fresh water and powerup. good luck
Mar 13, 2014 | As Seen On TV H2o Mop X5 5-In-1 Steam...
X5 steam mop, turns on but produces no st eam
Its likely that the tube that supplies the steam to the mop is clogged. you will need to disassemble the mop part and find that tube then push a wire up there to clear it out. Then turn the unit on and keep trying to clear with wire, you may want to wear a glove in case a sudden puff of steam comes out. This problem is common it happens because when you evaporate the water, any dissolved solids drop out onto surfaces inside the unit and make the clogs. The 'Motor' is real hot because the unit is making steam but it can't get out!
Nov 10, 2013 | As Seen On TV H2o Mop X5 5-In-1 Steam...
Main unit gets very hot but only sprays for 30 seconds then stops
This mop is only meant to pray for up to 2 seconds at a time. You should do one spray then swipe the mop over it and repeat. This is probably why it overheats.
Mar 03, 2013 | As Seen On TV H2O Mop X5
With an H2o X5 steam mop spurting water
I had the exact same problem with mine. I don't know if it's on purpose or not but it's obviously a common problem. I would just hold mine over the sink or bathtub for a few seconds until it started to steam.
Feb 27, 2013 | As Seen On TV H2O Mop X5
My h2o steam mop does not produce steam.I have only used it 6 times. I have tried using 1 part vinegar and 2 parts water to clean the system but no joy.
The H2O Mop X5 is designed to thoroughly clean floor surfaces, such as marble, ceramic, carpet, stone, linoleum, and sealed hardwood floors and parquet. Not all floor types are suitable for steam cleaning. For more details about h2o mop please visit ADS TUTORIAL
Oct 28, 2012 | Vacuums
Why are my wood floors not shining?
Well first off, I would not recommend using any time of steam mop on unsealed or natural wood floors. They will damage them because of the heat and moisture. If your wood is sealed then it would be okay for short amounts of time. meaning not keeping it in one position on a section of your floor for a long period of time.
Steam mops are not meant to Shine floors. They are meant to sanitize and disinfect. yes they do clean as well but if your floor is shiny after use then there is to much water coming out and not enough steam.
Sep 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My h2o mop will not allow any water flow the red light comes on after afrw minutes the green light comes on but there is no water or steam flowing out what can i do
Try running a solution of 1 part white vinegar to 2 parts water,turn on & let run through if this dosn't work take the mop head off ( unplugged of course) & poke a needle or paper clip through the hole replace head & try vinegar solution agian. It worked for mine you need to clean out lime scale.
Apr 13, 2011 | H2o TR220002 Steam Cleaner
As Seen On TV H2o Mop X5 5-In-1 Steam Cleaner With Elite Accessories Logo
180 people viewed this question
Top As Seen On TV Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an As Seen On TV Heating and Cooling Expert? Answer questions, earn points and help others
